Mostly XFX and eVGA from what I have heard, and mostly factory-overclocked 7900GTs but it applies to the whole 7900 series.Richdog said:I haven't heard much about this failure epidemic... s it really that bad? Any particular brands or models?
It's a fact they have the highest failure rate of any series graphics card in the last couple of years, I think XFX and eVGA actually published their RMA percentages at one point.Bennah said:Tbh, I have not seen loads of failed 7900 GT card stories about.
I think they are safe cards. Seen a lot of people around forums that are happy with thier cards.
Úlfhednar said:It's a fact they have the highest failure rate of any series graphics card in the last couple of years, I think XFX and eVGA actually published their RMA percentages at one point.
People are not making a big deal out of this for no reason.
Lost-Prophet said:What percentage of these are failing exactly? 50%+?
No, something like 5% RMAs but that's 50%+ more than usual which is where you're getting the 50%+ figure from.Lost-Prophet said:I was going to recieve a 7900GT for passing my exam results to but I'm not sosure now. What percentage of these are failing exactly? 50%+?
I am simply stating facts that the 7900 series (particularly factory-overclocked ones) have a stupidly high RMA rate of like 5% which gives them the worst failure rate since the 9800 Pro which were infamous in the beginning. Like I said, they are going to be replacing the Samsung memory on the 7900s with Infineon memory in the hopes of solving the problem, would they be doing this if there wasn't a reason?Bennah said:Got any links to these failures? Any percentages or what not?
Your making out that the 7900 GT is the worse card ever.
Plus, why get a X1800 XT instead of a 7900 GT?
Yeah, he was confused. The RMA rate is supposedly about 5% for these, which is about 50% higher than average according to eVGA and I think XFX confirmed it.Richdog said:Come on... 50%? That's just silly, it can't be that high.
Christ, some people. Look, I never said they sucked or were "a failure," I didn't even remotely imply it. All I said was that they have a high failure rate, there is a huge difference, so stop being defensive now if you please.Bennah said:The 7900 GT are great cards. I cant believe that they are getting slated for being failures, which they are not
Keep in mind the 7900s are also quieter, but you can get a Zalman VF900-CU with the difference plus a tiny bit of change. They also draw less power, so they're ideal for people with less powerful PSUs (although mine runs happily in my OCed system with tons of LEDs and cold cathodes on an Akasa 460w.)Eliot said:i though a 7900gt was roughly the same as a 7800gtx and a 7800gtx is roughly the same as a 1800xt, so why pay more a card that performs similar but doesnt do hdr+aa?
Úlfhednar said:Yeah, he was confused. The RMA rate is supposedly about 5% for these, which is about 50% higher than average according to eVGA and I think XFX confirmed it.
It's either the voltage regulator or the Samsung memory they've used. They're in the process of fitting the 7900s with Infinium memory to see if it solves the problem.Lost-Prophet said:my bad sorry to cause the confusion. I wonder what's causing the high failure rate
Úlfhednar said:It's either the voltage regulator or the Samsung memory they've used. They're in the process of fitting the 7900s with Infinium memory to see if it solves the problem.
Not a clue beyond what I have read on sites like Anandtech, but supposedly they are already up for grabs in the States.Lost-Prophet said:any thoughts on when they'll be released? My results are out on the 24th of August so hopefully they'll be out by then.
Úlfhednar said:No, something like 5% RMAs but that's 50%+ more than usual which is where you're getting the 50%+ figure from.
As for why I would suggest an X1800XT instead, my reasons are simple; They are faster at stock and don't need a pencil-mod to overclock high as they can adjust voltages through software, they are also cheaper and proven to be more reliable so far (which isn't bad for "old tech.")
I am not saying the 7900 series sucks, so look elsewhere if it is a fanboy fight you want. If someone wants a 7900GT that's fine with me, and I hope they don't have the problems that 5%+ of them have had so far, I just think it's important people understand the risks involved before buying because, as you said, you have never heard about all this so not everyone has. If you frequent sites like AnandTech and other hardware enthusiast pages you will have seen regular news updates from companies like eVGA who actually published their RMA figures.
Úlfhednar said:The main thing though is personal preference, and it's a very valid reason so long as someone actually takes the time to look at both cards before choosing. Obviously Richdog simply prefers the 7900, it could be because they're more efficient or because they're simply newer tech, who knows but it's his choice and I've seen enough posts by him to know that he's looked the X1800XT over enough to make an informed decision based on his needs and tastes. After all, that's why we don't just have one brand of graphics card.
