1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Portable TV electricity?
Discussion in 'General Discussion' started by Doosht, 21 Jul 2006.
  1. Doosht
    Wise Guy
    Can anyone give me an idea how much pence it costs an hour to run a plain portable colour tv?
    I know some of you maths heads out there can do this easy peasy :D
    tia
    Doosht
  2. ElRazur
    Capodecina
    I think you need to post some figures...should be at the back of the tv.
  3. Doosht
    Wise Guy
    im not at home where the tv is at the moment so i cant see. Any idea what the average consumption is of a 14" Colour TV?
  4. ElRazur
    Capodecina
    Im rubbish at maths but im sure someone will point it out. :)
  5. branddaly
    Wise Guy
    Its easy if you know the wattage of the tele. I don't.
  6. Doosht
    Wise Guy
    ok im home now and had a look....it says 33w!
    Doosht
  7. Doosht
    Wise Guy
    anyone? :cool:
  8. Dave
    Mobster
    33w = 0.033kw
    Call it 8p per kWh makes it out at 0.2p per hour :p
  9. PeterNem
    Sgarrista
    I was going to say 33watts seems a little low, so I looked on the back of mine... and it says 29 watts :o
    Can that be right?!
    22 watts / 240 volts = pretty much 0.1 amps, that's next to nothing.
  10. Doosht
    Wise Guy
    that seems very low! 0.2p per hour :eek:
    Not sure were my big time electric bill always comes from then.
    I need to look what the fridge and washing machine etc use then.
    Ta muchly
    Doosht
  11. james.miller
    Capodecina
    the killers are fridges and washing machines, but especially kettles, showers and your pc is a contributer also. (kettles and showers kill it though, as well as microwaves)
  12. Sirrel Squirrel
    Sgarrista
    Don't forget your PC, central heating, kettle, oven/hob if their electric.
  13. Adz
    Capodecina
    Anything that heats or cools is the real killer - electric heaters, towel rails, high power fans, kettles, electric ovens/hobs, electric water heaters (especially these), fridges/freezers (don't leave the door open!).
  14. Psycrow
    Mobster
    Avoid using the tumble drier too, they use a fair old whack of power. If you have an electric shower they use 8-10kw, so if you take ages in the shower thats going to be a huge drain. If your bill really is too high, try energy saving bulbs, turn the fridge and freezer temp down, dont leave anything on standby and dont put your pc under heavy load when it doesn't need to be.
