1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
power supply recommendations?
Discussion in 'Graphics Cards' started by misterpete, 31 May 2006.
  1. misterpete
    can anyone recommend a suitable power supply for a 7800gtx. Its on an Asus board 2gb ram 3.8 P4 2 ooptical, 2 SATA hard drives. My Antec true 550W will not work with it. any help is appreciated.
  2. davecarter
    Gangster
    I recently purchased a Tagan TG580-U15 and its an awesome beast, highly recommend it.
  3. xander_uk2
    Hitman
    Check out the Akasa Paxpower range.
    I have the 460watt LED version, and it's awesome. Pretty much silent too
  4. Darkwave
    Capodecina
    I have the exact same PSU. It's silent and a great PSU. :D
  5. senorstealth
    PermaBanned
    Got a Tagan TG580-U15 580W ATX2.01 Easycon in mine, running a 7800GTX.
    Runs sweet as, and very quiet
  6. senorstealth
    PermaBanned
    Second that
  7. Raikiri
    Capodecina
    Seasonic S12 (600w), tagan (580w) or enermax liberty (620w)
  8. wellibob
    Mobster
    I rate tagan, not the older duff 480w ones though.
  9. semi-pro waster
    Man of Honour
    What do you mean it won't work with it? You should have more than enough power in an Antec TrueBlue 550w to run pretty much any system out there, does it not have the connectors or what else may be wrong with it?
  10. misterpete
    I have tried a 7800gtx which tripped the power supply then an ATI 1800xt, that won't even get as far as tripping the power, nothing at all happens when I switch on. I am perplexed by the whole thing.
  11. poltergeist666
    Gangster
    I have the big Tagan 1100w jobbie - got big plans, and thought I'd start with a decent PSU. Not sure that I'm all in favour of the presentation suitcase that comes with it, as it's a bit of a gimmick.
    At least hopefully, if and when I get problems with the PC, I shouldn't have to look whether the system is getting quality juice. :D
  12. Jay_t
    Hitman
    I like the enermaz liberty and noisetaker, they seem to be very dependable :)
  13. smiley
    Gangster
    go for the hipper type r 580 w it looks bloody beautful it is a modular design so if you dont need all the power cionneters you can take them out to help the airflow in the case and also it almost totaly silent and very stable CHECK THE REVIEW AND SEE FOR YOURSELF
  14. Raikiri
    Capodecina
    Seasonic are better ;) :)
  15. Global_Inferno
    Hitman
    I'd say take a damn good look at the Hiper Type R too... It is gorgeous, and has yet to give me any problems, and im running a fairly Voltage dependant rig. (about to become even more with WC'ing!!)
