1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
PowerColor ATI Radeon X1900 XT - Noise
Discussion in 'Graphics Cards' started by sermad, 5 Jun 2006.
  1. sermad
    Gangster
    Hi guys,
    Can you fit aftermarket coolers to these that will quieten down the card? Is it worth it?
  2. Rob43
    Mobster
    Yes you can fit an aftermarket cooler on it,you won't go far wrong with a zalman VF900 ;) Or Arctic Coolers,but the zalman is the best at the minute
    It's worth it if you don't like too much noise :D
    Rob
  3. AFK_Matrix
    Wise Guy
    The other cooler is the Artic Cooling Accelero X2 Cooler. Just a word of warning do not throw your old stock cooler away or anything as if you try and RMA the card with one of these coolers on you will be told by ATI that you have voided the warranty.
    So if you do have to RMA the card put the stock cooler back on and bobs your uncle :)
