The missus has been quoted £169 for new front discs,pads and sensors inc fitting for her 325i. Is this a fair price? She was getting lots of vibration through the steering wheel on braking at high speeds... Thanks for any advice
Depends where the quote is from and what the parts are. I wouldn't pay an independant £170 to replace my disks and pads as a BMW main dealer will do it, using genuine parts, for £229.
was an independent 'specialist' on an E46- no idea on what make of parts. Thanks for that, food for thought.
As Fox says, depends on the quality of the parts - I don't know about the BMW specifically but it doesnt sound extortionate - I was once quoted nearly £300 for the same job on my Mondeo! That would have been a rip off Ask for a breakdown of the parts and labour cost, I normally do - helps you find out how expensive it is as you can find the parts price online
Thanks guys. We are both car repair virgins. I've had a company car all my life, which goes back in a few months and I think we are going to share the 325. The guy could have said it is £300 and neither of us would have had a clue...
It's part of the new BMW Value Service range of national fixed prices. on an E46, front discs and pads are £229 and rear discs and pads are £199.
The various responses here quote prices for replacing "disks and pads". The OP also referred to "sensors" - have you allowed for these and/or are these parts likely to be significantly more expensive to supply than possibly "generic" disks and pads? I ask because I believe that I will need to get the front disks and pads replaced before my next MOT.
Sensors are just 2 short wires that come out of the pad. It increases the cost of the pad by a few pounds. Generic pads can be obtained with these too.
BMW will replace these as well - they are inexpensive bits of metal which complete a circuit when the pad wears low to illuminate a light on the dash.
