1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Problem: Plate on gfx card bent - Help needed
Discussion in 'Graphics Cards' started by Kent, 26 Jul 2006.
  1. Kent
    Gangster
    Okay so I literally just got my x1600 and it fell out of the static bag onto the floor. :(
    No major damage although the end of the plate has bent in slightly.
    [​IMG]
    You see the bit at the end where is does a 90 degree turn, that bit has bent in slightly.
    The main question being: Will I be able to fix this and make it function properly or will it work anyway??
    Thanks. Please reply.
  2. ACESHIGH
    Mobster
    Shouldnt affect the cards performance as such. May make fitting the card a bit more difficult. You could just use pliers & bend it back (carefully).
  3. PinkFloyd
    Capodecina
    Just bend it back.
    Don't force it too hard just incase you do damage the card (unlikely)
  4. Kent
    Gangster
    Okay thanks guys, I just wanted a second opinion so that I know i'm doing the right thing.
