1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Problem with my computer
Discussion in 'Windows & Other Software' started by dominatrix1, 20 Jun 2006.
  1. dominatrix1
    Gangster
    [​IMG]
    This comes up when i turn my computer on, what does it mean and how do i get rid of it??
  2. Stelly
    Don
    What are the specs of your computer? and when does the error message come up??
    and I think that this should be in the software section
    Stelly
  3. dominatrix1
    Gangster
    It comes up every time i turn on *** computer specs are:
    2.17 Ghz AMD
    2 harddrives 1x 80 gb 1x 160
    512 mb Kingston Ram
  4. _PD_
    PermaBanned
    This happends because your computer, or a specific program, thinks that AUTOEXEC.NT is a virus and has killed it.
    Right click and "save as" here to get a replacement, and insert it into C:\WINDOWS\system32. Reboot and it should be OK.
  5. Stelly
    Don
  6. dominatrix1
    Gangster
    this may sound really weird but i cant seem to find the system 32 folder??
  7. _PD_
    PermaBanned
    C:\WINDOWS\system32
    Open up your C:\ , go to tools, folder options, click the view tab, and change the option to show hidden files and folders.
    EDIT: Actually, just copy "C:\WINDOWS\system32" and paste it into your address bar.
    EDIT 2: Of My Computer, not your web browser...
  8. dominatrix1
    Gangster
    thanks peopel the problem seems to be gone now!!!!!!!!
