1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Problems with system sound in Gnome/Ubuntu (Dapper)
Discussion in 'Linux & Open Source' started by Diss, 31 Jul 2006.
  1. Diss
    Wise Guy
    My sound works except for system sounds that don't.
    I followed these instructions but no luck:
    http://easylinux.info/wiki/Ubuntu_dapper#How_to_configure_sound_to_work_properly_in_GNOME
    Now my sound is OSS (using Nvidia sound drivers with onboard mobo sound) - is this why these instructions aren't helping - and if so any idea how to get it working?
    i have an oss.conf file where the esd one is but it only contains:
    OSSLIBDIR=/usr/lib/oss
    many thanks
    Diss
  2. Scythe
    Do you have a nforce chipset? I have nForce 2 onboard sound, these worked without messing around, but caused BSOD's in Windows today!
    What problems are you having? No sound at all? What nforce chipset are you running if any?
    Best places I found are the site you used, and Ubuntu's documentation.
    http://www.ubuntuforums.org/
    Is a great place for support that I used while setting Ubuntu up and fixing problems (1st time linux noob)
  3. Diss
    Wise Guy
    thanks scythe
    yep - its an nvidia chipset
    my (dual boot) winXP uses a XiFi card and works fine
    whats odd - to me anyway - is that its just the Linux 'system' sounds that won't work (mp3/games atc are fine) - they used to work on my previous sound card (an old soundblaster)
    thanks
    Diss
    PS - i haven't tried the ubuntu forums that much - i have always found that people here are much more helpful - i'll see if i get any other comments before giving them a go
  4. Una
    Wise Guy
    You really should be using ALSA now. Stupid question but are you sure your user who is playing sounds is added to the audio group? Thats a common problem.
    Is the problem /dev/dsp ?
    I can't really help you anymore than this without more specific errors messages - not just this wont work etc.. :)
  5. Diss
    Wise Guy
    hi Una
    I am not sure i can use ALSA? When i installed the nvidio drivers it just set up OSS and there wasn't an option for ALSA.
    In Sound preferences i have "enable software sound mixing (ESD)" and "Play System Sounds both ticked"
    Re "Stupid question but are you sure your user who is playing sounds is added to the audio group? Thats a common problem." - How do i tell?
    Re "Is the problem /dev/dsp ?" - I don't know what this means - i have a DSP file but its icon is some sort of chip and its not a config file (which is what i was expecting it to be.
    Anything else i can check?
    many thanks
    Diss
  6. Una
    Wise Guy
    The problem is often that your user does not have access to sound device correctly. Try running xmms music player as root or something and see if that gives you sound. If it does its likely to be the audio group thing.
    To see if your user is in the audio group check /etc/passwd (with some viewer).
    If /dev/dsp is there it is likely that the driver for your sound card is installed correctly.
  7. Diss
    Wise Guy
    i get this message when trying to play an mp3 in xmms
    ** WARNING **: alsa_get_mixer(): Attaching to mixer hw:0 failed: No such device
    ALSA lib pcm_hw.c:1305:(_snd_pcm_hw_open) Invalid value for card
    ALSA lib pcm_dmix.c:819:(snd_pcm_dmix_open) unable to open slave
    ** WARNING **: alsa_setup(): Failed to open pcm device (default): No such device
    the mp3 does however play in Amorak
    this is in the file you mentioned - but i am not sure what i am supposed to be looking for:
    root:x:0:0:root:/root:/bin/bash
    daemon:x:1:1:daemon:/usr/sbin:/bin/sh
    bin:x:2:2:bin:/bin:/bin/sh
    sys:x:3:3:sys:/dev:/bin/sh
    sync:x:4:65534:sync:/bin:/bin/sync
    games:x:5:60:games:/usr/games:/bin/sh
    man:x:6:12:man:/var/cache/man:/bin/sh
    lp:x:7:7:lp:/var/spool/lpd:/bin/sh
    mail:x:8:8:mail:/var/mail:/bin/sh
    news:x:9:9:news:/var/spool/news:/bin/sh
    uucp:x:10:10:uucp:/var/spool/uucp:/bin/sh
    proxy:x:13:13:proxy:/bin:/bin/sh
    www-data:x:33:33:www-data:/var/www:/bin/sh
    backup:x:34:34:backup:/var/backups:/bin/sh
    list:x:38:38:Mailing List Manager:/var/list:/bin/sh
    irc:x:39:39:ircd:/var/run/ircd:/bin/sh
    gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/bin/sh
    nobody:x:65534:65534:nobody:/nonexistent:/bin/sh
    postfix:x:100:103::/var/spool/postfix:/bin/false
    syslog:x:105:105::/home/syslog:/bin/false
    klog:x:106:106::/home/klog:/bin/false
    voteslave:x:1000:1000:voteslave,,,:/home/voteslave:/bin/bash
    messagebus:x:101:110::/var/run/dbus:/bin/false
    cupsys:x:102:107::/:/bin/false
    fetchmail:x:103:65534::/var/lib/fetchmail:/bin/sh
    hal:x:111:111:Hardware abstraction layer,,,:/var/run/hal:/bin/false
    saned:x:113:113::/home/saned:/bin/false
    gdm:x:104:114:Gnome Display Manager:/var/lib/gdm:/bin/false
    dhcp:x:115:115::/nonexistent:/bin/false
    haldaemon:x:116:116:Hardware abstraction layer,,,:/var/run/hal:/bin/false
    hplip:x:107:7:HPLIP system user,,,:/var/run/hplip:/bin/false
    beagleindex:x:108:65534::/var/cache/beagle:/bin/false
    ntp:x:118:118::/home/ntp:/bin/false
    vdr:x:109:120:VDR user,,,:/var/lib/vdr:/bin/false
    mysql:x:110:121:MySQL Server,,,:/var/lib/mysql:/bin/false
    mythtv:x:122:122::/home/mythtv:/bin/sh
  8. Una
    Wise Guy
    Hmm there should be a normal user in that list. Who you usualy log in as? Cant see it.
    EDIT: lol wrong file... Check /etc/group sorry
    Should be something like
    general:x:502:juan,shelley,bob
    but audio:x:whatever:users in audio group
    Also is /dev/snd populated?
  9. Diss
    Wise Guy
    thanks Una - file is as follows:
    username is voteslave
    root:x:0:
    daemon:x:1:
    bin:x:2:
    sys:x:3:
    adm:x:4:voteslave
    tty:x:5:
    disk:x:6:
    lp:x:7:cupsys
    mail:x:8:
    news:x:9:
    uucp:x:10:
    man:x:12:
    proxy:x:13:
    kmem:x:15:
    dialout:x:20:voteslave,cupsys
    fax:x:21:
    voice:x:22:
    cdrom:x:24:voteslave,hal,haldaemon,vdr
    floppy:x:25:voteslave,hal,haldaemon
    tape:x:26:
    sudo:x:27:
    audio:x:29:voteslave,mythtv
    dip:x:30:voteslave
    www-data:x:33:
    backup:x:34:
    operator:x:37:
    list:x:38:
    irc:x:39:
    src:x:40:
    gnats:x:41:
    shadow:x:42:
    utmp:x:43:
    video:x:44:voteslave,vdr,mythtv
    sasl:x:45:
    plugdev:x:46:voteslave,hal,haldaemon
    staff:x:50:
    games:x:60:
    users:x:100:
    nogroup:x:65534:
    crontab:x:101:
    ssh:x:102:
    postfix:x:103:
    postdrop:x:104:
    syslog:x:105:
    klog:x:106:
    voteslave:x:1000:
    lpadmin:x:107:voteslave
    scanner:x:108:voteslave,cupsys
    admin:x:109:voteslave
    messagebus:x:110:
    hal:x:111:
    slocate:x:112:
    saned:x:113:
    gdm:x:114:
    dhcp:x:115:
    haldaemon:x:116:
    ssl-cert:x:117:
    ntp:x:118:
    dirmngr:x:119:
    vdr:x:120:
    mysql:x:121:
    mythtv:x:122:
    I have no /dev/sound directory
    Diss
  10. Una
    Wise Guy
    Hmm that looks fine there. Its /dev/snd anyway not /dev/sound.
    What do you mean by system sounds anyway? The ones from your desktop interface(gnome/kde etc?)
  11. Diss
    Wise Guy
  12. Una
    Wise Guy
    It depends which desktop interface your using as to how it handles sounds. KDE uses arts and gnome uses esd. It sounds to me like its trying to use ALSA for your sounds when you only have OSS setup. Im not that well up on sounds to be honest, you might want to try ubuntu forums sorry :/
  13. Diss
    Wise Guy
    thanks for all the help una - i'll give the other forums a try
    cheers
    Diss
  14. Scythe
    So are you using XFI sound card, or onboard? Onboard might disable itself if it detects a sound card and XFI support wont be here until early 2008 as creative won't release anything for the drivers to be made.
  15. Diss
    Wise Guy
    hi Scythe
    winXP uses the wifi
    and Linux uses onboard sound
    Diss
