Hi Need some quick advice which PSU to order to go with an Antec 902 and a GTX295. Obviously it needs the power for the 2x GPU but also needs to fit this case. I am ordering both from here so something from this site if possible. Thanks Oh i have a brand new OCZ stealth x stream 700w - would this do the job or not??? Cheers Lads!
Phenom 3.4Ghz Quad 4Gb DDR3 GTX295 blue ray rom blue ray rw 320gb sata hdd o/s 1500gb sata hdd backup No other cards etc sound onboard tc. Thanks
I'm sure a 600w PSU should do you fine with room to spare from any respectible company. The Corsair hx 650w or 750w should be a very good buy. And any ATX or ATX + will fit your case. Note. My bad i missread, yes that OCZ should be fine.
well i was thinking about a corsair and as i have 2 hdd's 2 blue-rw's and a quad core cpu 4gb ddr3 i might need more power. gonna go for this one and hope its a good one Corsair TX 850W ATX SLI Compliant Power Supply
Corsair TX 850W ATX SLI Compliant Power Supply is a bit overkill for ur specs but what the hell good for future upgrades.
