1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Question about Coolermaster HAF 922 Fans
Discussion in 'Case Central' started by Makeem95, 14 May 2010.
  1. Makeem95
    I'm due to receive my HAF 922 case tomorrow (can't wait!) and I have a question about the fans on the case, specifically the two in the upper corner of the case, one blowing out the rear, one blowing out the top.
    I use a Titan Fenrir heatsink and the fan on this will blow air through the heat sink upwards and to the top of the case. This makes me think the other fan blowing air out the rear is largely redundant.
    Do people usually not use one of the fans depending on the orientation of their heat sink?
  2. Si105
    Hitman
    Why not use it? What harm could it do?
    Its still going to help cool regardless of whether its having as greater effect as if the heat sink was pointed at it. I can't see any reason to remove it unless its hideously noisy or something.
  3. Makeem95
    I was thinking about the noise, but now that I've installed my PC in the case and have it running, it's very quiet anyway so I've decided to keep all the fans running as you said.
    It is a fantastic case, my CPU temp has dropped by 5 degrees in the HAF. :)
  4. Akempster
    Gangster
    my rear fan is useful in my haf 922. ive got 2 on the side blowing into the case andnd the added pressure pushes all the hot air up out the rear fan - deffinatly keep it or if you want usse it as an exhaust fan on the bottom of the side panel to sort out your graphics card
  5. Makeem95
    That's a good idea, though I've only got one 8800 gt card in there so heat isn't an issue. When I upgrade, something to think about though. :)
    Even without any side fans, I can feel quite a strong current on the side from all the air getting pulled in by the rear and top fans. I stuck some fine mesh on the inner side of the side panel to filter out the dust that was probably getting sucked in.
  6. Akempster
    Gangster
    yeah, watch out if you do go with side panel fans on this case - my grill gets a layer of dust each day =)
