1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Question for Linksys WAG354G users
Discussion in 'Networks & Internet Connectivity' started by leaskovski, 16 Jan 2006.
  1. leaskovski
    Sgarrista
    Hi all,
    I am trying to help get my brother connected to his AOL account using a Linksys WAG354G. Now we have got his account in tapped in and we have set it up to connect via PPPoE. The strange thing is, on the status tab of the HTML config pages, when i look into the Gateway Status Tab, it say that the login is down, but yet my brother is still able to connect to the internet via the Linksys WAG354G. He is connected via a network cable and via wifi. His machine has been assigned an IP for the wifi connection and it is reporting it to be connected fine, but if we then unplug the network cable, he can nolonger get onto the internet. It is as if the box does not want to route the wifi traffic.
    Should the gateway status page tab be reporting the IP assigned by AOL?
    Cheers
  2. VeNT
    Capodecina
    have you checked up on your Wireless settings, alowing setup over wireless try logging in and seeing what it says then?
  3. leaskovski
    Sgarrista
    Yeah, we can connect to the box via the wifi.
    What does your gateway status page say when you are connected?
  4. Burbleflop
    PermaBanned
    Change the router to PPPoA instead of PPPoE, also set the MTU to 1400 while you're in there.
  5. leaskovski
    Sgarrista
    Okay, i figured that after reading up on Adslguide a lot of people recommend this. Is there any reason?
  6. Burbleflop
    PermaBanned
    Any reason for changing the MTU? Yeah, that's what AOL's network is configured to work on. It is a bit non standard, but that's nothing new with AOL.
    For what it is worth, you would have a semi-working internet connection if you didn't change the MTU to 1400, but you'd have odd problems with sites (particularly https) not loading.
    MTU = maximum transmission unit btw, it is the maximum size in bytes that a packet of data can be. If the MTU on your equipment is too large you'll get packet fragmentation which is bad.
  7. leaskovski
    Sgarrista
    Opps, yeah i knew all that. What i should have said was the PPPoA and PPPoE. I have always used A on my network with PlusNet and Pipex but for some reason AOL ask you to use PPPoE. I'm not sure if this is something to do with AOL's supplied modem (rubbish thing) or just them talking carp.
  8. tolien
    Caporegime
    The latter. It's PPPoA either way (on BTw ADSL), the fact you throw in some ethernet to keep AOL's network happy isn't important.
    AFAIK, PPPoA works too (and would work faster, and with less latency).
  9. ants83
    Wise Guy
    mines as follows
    PPoA
    multiplexing VC
    QOS type UBR
    VCI 38
    Dunno if this helps or not
  10. leaskovski
    Sgarrista
    Thanks. I think that we need to update the firmware for the box as well.
    Can anyone confirm what information is displayed on the gateway status page within the config webpages? Does it get updated with the IP/DNS settings from the ISP DHCP server?
    Thanks
  11. tolien
    Caporegime
    It's not DHCP, but yes, it should get the details from the ISP.
  12. leaskovski
    Sgarrista
  13. leaskovski
    Sgarrista
    Right! We got this working in the end.
    It turns out that when my brother created a screen name for the router to login with, AOL automatically Capitalised the first letter, thus it wasn't able to logon properly!
    Doh! Thanks all for the help guys.
