1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Question regarding case air-flow, old Chieftec case and Seasonic X-650.
Discussion in 'General Hardware' started by JasonM, 10 Jun 2010.
  1. JasonM
    Mobster
    I have a rather old Chieftec Midi Dragon, it's the version with just 2 x 80mm rear fans. It's out dated but I've owned it since 2001, at some point I accept I should upgrade it.
    Currently it's fan configuration is as follows. The 2 x 80mm rears have some PWM artic cooling 90mm fans installed. At the front there is a single 80mm blowing air in. The only other air extraction is the fan on the GTX 260, and the OCZ 600w that extracts at least the volume of air of all other fans conbined.
    I have just ordered a Seasonic X-650 to replace the OCZ 600w, part of the reason was the fan in the OCZ was becoming too noisy, plus the X-650 was on offer.
    Here is the question. The x-650 is semi passive cooled will there now be enough air flow over the system, or will the X-650 give sufficient flow once temps raise up?
  2. snaggster
    Hitman
    I would splash out on a new case. I have a gtx260 and know just how hot they get. That new silverstone for £49 on the new products section looks good.
  3. JasonM
    Mobster
    Yes thats good advice, and should really consider another case. Even £40 on the Antec 300 would be an upgrade.
  4. JasonM
    Mobster
    Well I fitted the X-650, the fan does not spin! It also appears to give off little / no heat. This PSU is from another world, I think ET made it!
    The crazy thing is air is being pulled into it (from outside) via the case exactor fans.
