1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Quick question on i5 barebones system
Discussion in 'General Hardware' started by cambb, 9 Mar 2010.
  1. cambb
    Gangster
    looking at the barebones overclock i5 system and was wondering if i wanted 8gb of memeory instead of the 4gb would i be able to install it myself or would the OC be able to do it and achieve the same overclock?
    Thanks
  2. Redmint
    Mobster
    This isn't from personal experience but I've heard that 8GB configs can limit the maximum overclock slightly. However if you call the OCuk team they will still be able add the extra memory to your build and they should tell you what the overclock will be with 8GB.
  3. cambb
    Gangster
    Thanks for the advice i'll ring them
  4. RJC
    Don
    I think that will be your best bet, as normally more ram does decrease your overclock slightly.
  5. shadow_boxer
    Sgarrista
    Please let us know how you get on. Thanks.
