Hey
Just a daft chew the fat question, but the rear discs on the car I noticed are now suddenly scored. 3 noticeable rings, but interestingly, on both sides, and just the rears. They've only covered 10k miles although I guess it can happen at any point in time. The discs were fine a few days ago so obviously something has gotten in... grit or stones in the road perhaps? What is the usual culprit?
They seem to have appeared after the handbrake was stuck on, could that be a cause? Might just be coincidence that though.
I just thought it odd for both sides to happen at the same time.
I have been planning to replace them, not sure if anyone here has the infamous "moo" sound or experienced it, when reversing. Apparently a very common VW / Skoda / VAG issue. So I was going to put some discs on with some slight grooves and a softer compound pad to see if that helps, although some people say it is resonance. VW still no wiser in fixing.
Thanks.
Thanks.
