1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Recommend me a wireless ADSL router
Discussion in 'Networks & Internet Connectivity' started by InQ, 8 Jun 2006.
  1. InQ
    Wise Guy
    Replacing my desktop with a laptop and i'm looking to get a wireless ADSL router to replace my ADSL USB modem.
    What can you recommend I look at getting?
    Budget is ~£100 and i may want to add a hard drive to the router for wireless backups at a later stage (if it has any bearing on what to buy!).
    I've been looking at the Linksys WAG54GX2 Wireless-G ADSL 2/2+ Gateway with SRX200 but i'm wondering if a MIMO router would be overkill?
  2. MarcLister
    Capodecina
    I've just bought a Netgear DG834PN and I love it. It was easy to set-up, took me less than 2 minutes from turning my PC back on to getting online.
    I was looking for an old thread I posted in and have just updated the thread with info and more questions. Whilst looking for it I saw this thread and although it is a few weeks old I thought I might as well post here and see if you've already gotten something or not.
    If you haven't then I think the DG834PN will do what you need it to do.
  3. InQ
    Wise Guy
    Cheers...i'd forgotten about this thread!!
    I've now got a 3COM Officeconnect (3CRWDR100A-72) 11g wireless router from a mate for £30, it hadnt even been used as he ended up getting cable and not ADSL.
