1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Replacement Celeron motherboard....
Discussion in 'Motherboards' started by conuk, 5 Jun 2006.
  1. conuk
    Wise Guy
    Replacing a motherboard in a friends Emachine 410 (!)
    It has a 2.40 ghz celeron in it...
    anybody care to recommend a cheap replacement ? (shes gave me £50) to spend but can get more....
    (present : agp Radeon 9200 - 512 ddr memory - onboard sound...)
    so its nothing flash :)
    Havent had Intel for ages so your thoughts are appreciated :)
  2. basmic
    PermaBanned
    Just get a cheap Socket 478 motherboard. I'm afraid I can't say where, because I'd be linking to competitors. :(
  3. VoG
    stick an ASUS P4DV800D-X in it, you can get em for under £30 if you shop around & there AGP and PCI-E on the same mobo, so at a later date she can stick a PCI-E gfx card in if she can't find an agp card.
  4. conuk
    Wise Guy
    thanks fellas - socket 478 it is :)
  5. FatRakoon
    Capodecina
    Id stick with the Mobo she has and get a cheap Pentium instead!
    Even if the Mobo is broken, it will still be quicker! LOL
    Check out eebhay? Look for S478
    I wouldnt waste up to £50 for a Celeron based PC mate... I would consider getting a cheap-o Pentium and Mobo as its going to be an improvement over the Celeron.
