- 14 Sep 2007
Hi Guys,
What type of wireless card do I need to replace a Dell Inspiron 1720, is it a mini PCIe card?
Also I am replacing the wireless card in this laptop due to when it is enabled in the BOIS the laptop crashes (as in completely freezes/hangs while windows is starting up or when loading the desktop and non responsive, only way is to hold down the power button).
This also after doing a complete re-install of windows Vista and having the correct drivers from Dell installed.
Also the connections to the card are definitely secure as I check that. Is the wireless part of the laptop dead? as when using Ethernet connection it works completely fine.
Thanks
Dazza
Thanks
Dazza
