The Panavia Tornado Air Defence Variant (ADV) was a long-range, twin-engine interceptor version of the swing-wing Panavia Tornado. The aircraft's first flight was on 27 October 1979, and it entered service with the Royal Air Force (RAF) in 1986. It was also previously operated by the Italian Air Force (AMI) and the Royal Saudi Air Force (RSAF).
The Tornado ADV was originally designed to intercept Soviet bombers as they were traversing across the North Sea with the aim of preventing a successful air-launched nuclear attack against the United Kingdom. In this capacity, it was equipped with a powerful radar and beyond-visual-range missiles; however, initial aircraft produced to the F2 standard lacked radars due to development issues. The F3 standard was the definitive variant used by the RAF, the RSAF and the AMI (which leased RAF aircraft).
During its service life, the Tornado ADV received several upgrade programmes which enhanced its aerial capabilities and enabled it to perform the Suppression of Enemy Air Defenses (SEAD) mission in addition to its interceptor duties. Ultimately, both the RAF and RSAF retired their Tornado ADV fleets; the type has been replaced in both services by the Eurofighter Typhoon.
Origins
The Tornado ADV had its origins in an RAF Air Staff Requirement 395 (or ASR.395), which called for a long-range interceptor to replace the Lightning F6 and Phantom FGR2. The requirement for a modern interceptor was driven by the threat posed by the large Soviet long-range bomber fleet, in particular the supersonic Tupolev Tu-22M. From the beginning of the Tornado IDS's development in 1968, the possibility of a variant dedicated to air defence had been quietly considered; several American aircraft had been evaluated, but found to be unsuitable. However, the concept proved unattractive to the other European partners on the Tornado project, thus the UK elected to proceed in its development alone. On 4 March 1976, the development of the Tornado ADV was approved and it was announced that 165 of the 385 Tornados that were on order for the RAF would be of the air defence variant.
In 1976, The British Aircraft Corporation was contracted to provide three prototype aircraft. The first prototype was rolled out at Warton on 9 August 1979, before making its maiden flight on 27 October 1979 with David Eagles. The second and third development aircraft made their first flights on 18 July and 18 November 1980, respectively. During the flight testing, the ADV demonstrated noticeably superior supersonic acceleration to the IDS, even while carrying a full weapons loadout. The testing of the prototypes was greatly aided by the use of real-time telemetry being broadcast back to ground technicians from aircraft in flight. The third prototype was primarily used in the testing of the new Marconi/Ferranti AI.24 Foxhunter airborne interception radar.
The Tornado ADV's differences compared to the IDS include a greater sweep angle on the wing gloves, and the deletion of their kruger flaps, deletion of the port cannon, a longer radome for the Foxhunter radar, slightly longer airbrakes and a fuselage stretch of 1.36 m to allow the carriage of four Skyflash semi-active radar homing missiles. The stretch was applied to the Tornado front fuselage being built by the UK, with a plug being added immediately behind the cockpit, which had the unexpected benefit of reducing drag and making space for an additional fuel tank (Tank '0') carrying 200 imperial gallons (909 L; 240 U.S. gal) of fuel. The artificial feel of the flight controls was lighter on the ADV than on the IDS. Various internal avionics, pilot displays, guidance systems and software also differed.
The Tornado F2 was the initial version of the Tornado ADV in Royal Air Force service, with 18 being built. It first flew on 5 March 1984 and was powered by the same RB.199 Mk 103 engines used by the IDS Tornado, capable of four wing sweep settings, and fitted to carry only two underwing Sidewinder missiles. Serious problems were discovered with the Foxhunter radar, which meant that the aircraft were delivered with concrete and lead ballast installed in the nose as an interim measure until they could be fitted with the radar sets. The ballast was nicknamed Blue Circle, which was a play on the Rainbow Codes nomenclature, and a British brand of cement called Blue Circle.
Tornado F3
Production of the Tornado ADV was performed between 1980 and 1993. The Tornado F3 made its maiden flight on 20 November 1985. Enhancements over the F2 included RB.199 Mk 104 engines, which were optimised for high-altitude use with longer afterburner nozzles, the capacity to carry four underwing Sidewinder missiles rather than two, and automatic wing sweep control. The F3's primary armament when it entered into service was the short-range Sidewinder and the medium-range Skyflash missiles, a British design based on the American AIM-7 Sparrow. The F.3 (originally F.Mk3) became operational in 1989, with an automatic maneuver device system incorporated, enabling the flight control computer to automatically adjust the sweeping the wing to obtain the optimum flight characteristics. This was similar in concept to the automatic sweeping wing (ASW) capability of F-14, a capability that greatly enhanced manoeuvrability but did not exist on any previous Tornado IDS and ADV models.
Aires 1/48 Martin Baker MB Mk.10A ejection seats # 4499
Eduard Zoom set - Panavia Tornado F.3 ADV
Eduard seat belt set - FE881
Eduard Brassin ED648159 - Panavia Tornado wheels
Efuard Brassin AIM9 Sidewinder Missiles
Master MR48032 - Panavia Tornado Pitot Tube and Angle of Attack probes
Model Alliance Decals MA-48106
Origins
Tornado F3
- Kit Manufacture: Revell
- Kit Number: 03925
- Scale : 1/48
- Type: Panavia Tornado F.3
- Extras: Aires AIRE4675 - Panavia Tornado WHEEL BAY
- Paints: Mr surfacer 1500 primer, Hataka, Mr Color and various Tamiya. Xtracrilics deset sand/pink for drop tanks.
- Weathering: Flory models Dark Dirt Wash and grey wash for fin.
