After some suggestions on changing an old groupset and what to change it to...
The other half has old Shimano 8-speed Tiagra (2300?) on her commuter and the FD is pretty toast (rust & corrosion). Rear is ok, shifters could do with changing... They're the ones where the cable enters the side of the lever rather than being under bar and she keeps knocking them screwing up the indexing. Scuffed as hell and the shifter movement isn't very good any more so putting quite a strain on cables. The threaded BB is still good but the cranks have seen better days. The corrosion on the old FSA arms/rings/bolts makes me think I'll struggle to get them off to replace with anything so will be a removal of cranks to change rings. So I'm playing with the idea of changing everything for her over to something newer rather than just buy a FD. Budget would be the main concern, so what I do with the shifters will determine really what I do with the rest of it. Guessing sticking with the square taper cranks (so keep the BB) would be the best bet, but do I go with keeping her on 8 speed shifters (R2000?) so I don't have to change the RD, then spend the money on some good cranks, or do I change everything up to 10 speed (
Tiagra 4700)? Might be more deals on older (but new) 10 speed components than going for something new like R2000?
Some good info, thanks. I might order some of those Lifeline, just to keep about for emergencies at that price!
Yeah after noting that price I picked 2 up myself for the other half when she next needs tyres...! Although seeing her GP 4Seasons the fact they've done 2 winters and she's terrible about keeping the pressures up on them, they're doing surprisingly well. Minimum amount of cracking on tread and sidewalls look good.
Sorry for late reply mate, ended up going with Lezyne Lite Drive 1000XL/KTV Pro Light Set for £60
https://www.probikekit.co.uk/cyclin...-drive-1000xl-ktv-pro-light-set/12116504.html
Different reviews say batteries don't last long, I am yet to test them fully. If they only last 2 hours.. then thats plenty enough for me.
Cheers
Good deal for that price.
People talking about batteries on Leyzne lights are generally not talking about burntimes/charge - but the life of the battery. They tend to degrade so the amount of burntime decreases with life of the light. I've only had 2 of them and both of them certainly have that issue: (
Macro Duo helmet light), equally the battery was kinda ok to change over, fitting an unbranded ebay £15 knock-off but broke the rear LED doing so, now it's mounted as a front light on the Chariot. My other Leyzne is a backup
Hecto Drive 300XL I carry in my commuting bag for emergencies. 15 mins plugged in is enough charge for me to do a ~30 min commute, but it doesn't hold it's charge if I've not used it for a few months. Probably never used it long enough to really test the burntime decrease but it was only £16...!
I’m looking for a decent front too, how does the lezyne compare to an exposure strada, anyone?
The Lezyne is a cheap good light. They're generally slightly better made than Cateye (metal rather than plastic bodies) with generally slightly weaker LED's/non-focussed as not totally aimed at road riders like most of the Cateyes (which generally conform to the German/Euro lighting regs which are strict).
Exposure are premium lights, with features and builds to match. You won't be disappointed with the Strada. I love my Race, but really need to pick up a remote switch for it.
IMO if you can afford Exposure lights, 100% buy them. They are the best out there.
Agreed. They're a brand which are so good they encourage you to keep going back to their products. If I'm wanting a light and there's an Exposure in/near the price bracket I'll get one.
Thanks folks. I have a blaze and the quality is good just wanted to check on the actual light quality. Has anyone used a mount to attach it under a wahoo roam?
I had mine mounted to the underside of my K-edge combo with an ELEMNT on top. Worked well, but changed it back to bar mounted (underslung) as wanted my camera back on there.
Ordered the Strada sb from wiggle, I’ll have to look at mounting options. Cheers folks
My K-Edge combo XL has been rock solid over several years with an Edge 800, now an ELEMNT and an original Garmin VIRB underslung. Almost daily use and impressive build quality, but not cheap. Barfly are not cheap either. I bought my K-Edge as the garmin one then
bought the puck for Wahoo from Mantel (I think, can't see it now but
Sigma did stock them)...
Some here.
