Only an issue for the <80kg rider who lifts themselves up in the air instead of being able to push the pump handle down
Although @Shadowness those wheels look a-mazing! I would love a set for my P2...
Thanks that really helps and pretty much what I'd got to myself was just second guessing.Sounds like IS42 and IS47. Sometimes have to be creative with the bearing cap or use the old ones. That airevelo site is good or we get in headsets from mpart. Using enduro bearing I think.
Rsp from raleigh have IS47 too.
Haha! Tell you what, the little 'double action' Topeak hand pump I recently got would be good for that. It's short throw so easy to no wobble around as you pump and double action so you get resistance both ways. Although I'll admit it took me about 80 pumps to get a 25mm tyre up. Pumping furiously with my weedy arms, but very little change in resistance when pumping until I hit around 100PSI lolHaha this was literally in my home the other day as I tried to get to 80psi!
Can remember a discussion before about using 2 vouchers there but can't recall which they where. Seem to recall that different stores did it differently and some you could get away with doing it, others not so lucky... Think the general T&C's/small print is vouchers couldn't be used together...Does anyone know if you can apply the british cycling discount alongside a cycle2work voucher at Halfords? I vaguely remember it being discussed before but can't find it.
What's the best deal around for a power meter at the moment?
Stages 105 for £254 on mantel. Still wish I'd picked up the 4iiii for £185 pre corona
Still a good price. Got my 4iiii between those prices SH and have been really happy with it. It's certainly worth £250-300 and I imagine the Stages is too.What's the best deal around for a power meter at the moment?
Not sure why you'd consider one of them, unless you where already riding with power and where TT'ing fairly seriously. They're just not accurate without frequent 'calibration' rides in the same conditions to use as a baseline, then all it would take is passing vehicles/gusts of winds to throw it's calculations out far enough that you'd regret buying a DFPM instead...I am actually really tempted by the PowerPod v3... Was £250-odd on PBK a couple of weeks ago.
I didn't find the Tempo breathable enough for the type of riding it seemed designed towards - fast & hard efforts. The pit vents where too small and it needed some other way of getting air into the torso. It needed some other vents, probably zip-able on the front and flapped on the back, like their more casual jackets. I found it almost as sweaty as a rain cape, just glad it sold well online and I got my money back. I've long been a fan of DHB jackets/winter tops, I've owned 5 of them, but have found their Aeron/ASV/Pro line kinda missed the mark for me (usually due to ventilation/features rather than fit/quality).dhb Aeron Tempo 2 jacket has been just the ticket for me since the autumn weather started. Super breathable and good water resistance.
Ribble sent me 4 Season 28mm in August last year instead of the 4000s II's I requested. I couldn't be bothered to send them back, so popped them on and have been running them ever since, including through summer. Excellent tyre, haven't had the slightest bit of trouble from them. They're definitely slower than the 4000s II, but it's to be expected given the type of tyre it is. Just like something I can rely on.
Anyone got any recommendations for for this time of year? Usually use Muc Off Dry Lube but interested if there's anything better- particularly something that doesn't need applying too often. Sounds like their wet lube leaves tar-like deposits on the chain which doesn't sound ideal.
https://www.probikekit.co.uk/cyclin...-3d-power-meter-105-r7000-black/12104435.html £275 with the current TOP10 promo code.
Edit: discount limited to £25
