Windproof softshell recommendations for this kinda 6-15 degree 'not quite cold' weather?
I've got a couple of
DHB Windslam Blade 'jerseys' which are superb but getting quite old/worn now. One of the zips has started to go. None of the DHB replacements since have come close to fit/function/fabric of the 2015 Blade (I've tried most of them through the years). The general
Sportful R&D Wind jerseys I've used lots other years are superb but a little too warm/insulated for the upper of that range (like we're seeing now), being more suited to colder 0-10 degrees. I have Castelli Team 'Winter' Jackets (
design is like the Arctic /
Transition jackets/jerseys) which again are a little too warm for this weather (although less insulated than the Sportful).
Currently looking at the
Endura FS260 Jetstream II, but price is quite ripe considering I'm probably after several of them...! I've been able to get away with 2 tops so far, but with an increase in chariot days coming I don't want to double up too much and certainly not 3 days in the same jersey
Gwads dammit! Then it really is downhill from here.
When can I have my midlife crisis to justify this?
Interestingly, have read with the new Tarmac SL7 the frames in the S-Works, Expert and Pro are all the same stiffness and geometry. Just with different paint and carbon used so the S-Works are lighter (800g) using FACT 12r over the FACT 10r (920g) frame in the Expert and Pro. Previously the Expert and Pro where slightly different geometries, not as stiff and heavier due to the different carbon layups. Not any more (according to their marketing). Sounds like the finishing kit and the wheels are the biggest changes between them. They all have the new (amazing) integrated bars for 2021. I'll happily ride a bike 120g heavier for a £6250 saving!
The expert even comes in this insane/crazy kinda oilslick colourway:
https://www.sigmasports.com/item/Specialized/Tarmac-SL7-Expert-Disc-Road-Bike-2021/RE0A so tempting... *drool*
@Roady all cables apart from the first dura ace version. You want sd50s with the round plug. E tube is the software protocol I think.
Thanks! I'm guessing everything has to be e-tube compatible for e-tube to work, just can't in my mind see how the cables seemingly being no different makes any odds to e-tube. Pffft. Know you've got several di2 setups, used e-tube?
Thanks for the previous recommendation to look at other/older DA di2 before. It's working well so far for me - I got a set of 7970 levers & FD, external battery, mount and some cables. If I can pickup a RD for a good price, then it'll be a di2 setup for <£250?!
I'll be then set to convert the turbo bike to 10-speed di2, I'll then swap the 5800 11-speed from there over to the other halfs bike to replace her old 8-speed. Crazy it's going to work out cheaper than buying S/H mechanical 10/11 speed for her. I also have part of what I need to setup mine to di2 but that'll be 11-speed. I have di2 785 shifters and a 6870 FD, just want an 8050 RD so I can run a 34t rear cassette... Have no battery or control boxes for that so it's going to work out quite a bit more expensive than the 10 speed...
Would you take a punt on a S/H internal battery, or are they the sort of thing which fails/is buggy/problematic so always best to buy new?
I'm 6ft 2, no idea on bike sizes!
Really depends on your inner leg, you'll likely be a 56cm in most road bikes unless you have long legs which will probably push you to 58cm.
As for recommendations - get whatever you can find within your budget if buying new - bikes are still in quite short supply/scarce across the whole industry/country! Even better if you can find a S/H bargain, but again due to demand it could be easy to get caught out.
