Megamasher I see you're really close to me. If you do order can I get you to order a part as I don't want to pay 7quid postage on a 7quid part.
yep it's for my cx bike and works fine without it.Depends can you wait till september and I'm back in portsmouth? Postage still may be cheaper though either way
Lol it's Armageus' annual I broke something post, so prepare for some "noob" content:
Noticed in the last few days gear shifting started to become less than smooth, so have checked chain length and is over 1% with one of those wear gauge things that I should use more often.
However looking at the rest of the drivetrain, the Cassette looks fine, but all 3 of my chainrings are in bad shape ("shark teeth",as well as a couple of very square broken looking teeth, and general corrosion).
edit: realised this is just the shape of the smaller and mid rings and specific teeth to assist in changing gear
Assuming I should replace the whole lot, and would like to give it a go myself (rather than pay anyone - upon checking cassette realised local LBS had fitted "wrong" cassette last time).
Bike is a 2011 Lapierre Audacio 200: Shimano Claris 2300 8 Speed Triple (Cassette should be 13-26 although has a 12-25 fitted, and chainrings are 52/42/30).
1. I have a generic Aldi bike toolkit which has a chain rivet extractor, freewheel remover, crank arm remover, chain whip etc - is there anything else I need in that regard?
2. For cassette I assume I just need: http://www.wiggle.co.uk/shimano-hg50-8-speed-cassette-road/
3. For chain what is the difference between these: http://www.wiggle.co.uk/shimano-cn-hg40-6-7-8-speed-116-link-chain/ http://www.wiggle.co.uk/shimano-hg71-678-speed-chain/? And presumably they are long enough?
4. Not sure which chain rings I need? Appreciate Claris 2300 is "old tech", but surely must be able to get parts?
EDIT: In retrospect, only really need the outer 52T Chainring (as barely use the middle and don't use the small, and can presumably just clean them up and re-spray to make good?)
Is stamped as an SG A-52, having measured between bolt holes (76.4) and non adjacent bolt holes (123.6) looks to be BCD of 130 (based on Sheldon Brown table)
This might be the closest I can find?
https://www.sjscycles.co.uk/chainri...r-chainring-d-type-silver-50t-for-chainguard/
https://www.ribblecycles.co.uk/specialites-ta-cring-shimano-130mm-8-9-10-spd/#pid=21529
Have had a look at the GCN youtube videos and seems reasonably straight forward, but any other tips would be appreciated.
Thanks
k cool. send me link of what you want. sort getting it to you lateryep it's for my cx bike and works fine without it.
Do you get it more when laying down any higher wattage? More when out of the saddle? Could just be grit between pedals/bearing covers/bb interface?I've got some wierd horrible creak coming from my Ridley and I cannot for the life of me work out where it is coming from!
It's mainly the left side so I thought it was the pedal, no play in this or the cranks, so checked everything associated even taking apart the rear freehub etc and cleaning it up, along with cassette etc, still there. Going to try the bottom bracket next but will have no idea where to go if it isn't that. Haven't had any horrible noises for a while and forget how frustrating they are to solve.
Haha yeah, me too!I could live off Moussaka!
Yeah a fair bit. Though all my excuses failed today. 1000m, 67km and 35c! Ran out of water about 36km in, luckily found a shop in the next village.
I know it's a bit late now, but I personally would've looked to move to 10 speed.Assuming I should replace the whole lot, and would like to give it a go myself (rather than pay anyone - upon checking cassette realised local LBS had fitted "wrong" cassette last time).
<snip>
I picked up a cheapy Toppeak version and actually surprised how much I've used it rather than the bigger clicker types! So quick & easy to just grab and use without having to set anything.
http://www.chainreactioncycles.com/shimano-tiagra-4700-10-speed-groupset/rp-prod138440
http://www.chainreactioncycles.com/shimano-tiagra-4700-double-10-speed-crankset/rp-prod137764
There's also still some fantastic deals to be had on Ultegra 6700 and 105 5700 if you can find them, also second hand/barely used!
Ha sorry for my terrible explanation. What I did was, put it in the bottom pic position, and then push forward the RD cage/ OSJWs as far as it goes (towards the front of the bike) until it locks out in the forward position, then let it go back slightly from that position, so it isn't fully tight and use that as your chain length
MegaMasher you have no trust! Are you able to set it up so I can send you an email, or if you trust me I can return your email.
