yea im ok and so is the bike thanksHope you're ok.
What did you order? [my memory is rubbish]New bike incoming
New bike incoming
Good choice, is that the purple and red one? Pictures online don't do it justice, in the flesh it looks superb! Or is it the Black & Red one? Looks even better IMO (but not seen one in the flesh), easier to match kit/tape/cages etc with.Scott Foil 20, it's a 2017 but it's never been out of the box. Specifically went looking for a 2017 as I don't like the 2018 colour options.
Measured this Thru axle for length last night and it's not going to be enough. So I'm back to buying a specific adaptor (& the possible nightmare of matching the thread of my thru axle!). Annoying the options all seem very expensive for what they are!My current thinking is to use a Tacx trainer adaptor I have (as it's much longer/wider than my frame) and get a locking nut for the end so the adaptor had no chance of undoing.
Guys what do you think to this wheelset?
https://www.tredz.co.uk/.Mavic-Cosmic-Pro-Carbon-Exalith-Road-Wheels-2018_98701.htm
I'm looking to use them on my tri bike that I use for all occasions. Ironman races, sportives, training etc.
Don't want to go all out aero and equally don't want all out climbers wheels, but are these maybe just bad all round?
Pics? The one I linked?Gloss black and gloss red Roady.
The only slight problem is that the DT Swiss wheels are more charcoal.
You'll probably find they look fine, being more matt and slightly different colour they should stand out a little, in a good way! If they where gloss black and a slightly different shade of black or slightly different gloss then they might look a bit too odd/different.
Obviously they'll be travelling so fast nobody will notice!
Looks good - needs some deeper section wheels thoughScott Foil 20, it's a 2017
Ah yeah, screwed my links up, was looking at this 2017 on Sigma?
