- 1 Dec 2015
^^^^ mmm klavv do £200 for 64GB of ram at 3200hz and slightly more for 3600hz, like £240 odd.. ouch at £300
Pricing caught @tamzzy eye haha
Yea so when I said I tried to give as much love to OCUK as possible, they didn't get the love for that particular item, which was out of stock at OCUK anyway
Isn't there one built in? I know Corsair does...
Depending on the motherboard, you shouldn't need a fan controller. I currently use the sysfan headers for all case fans which are controlled with either a custom curve or manual presets using the Gigabyte utilities software - I have been using it this way for 5 years and it's never caused an issue.
I will have 9 case fans
Thats not including the AIO pump which pretty sure connects to a further.
So I previously used a splitter, so 2 per header and the AIO pump will connect to the pump header (on newer boards) or the CPU header on older boards. The AIO may have it's own controller for the fans. I know the older corsair units would have the fans connect to the pump shroud.
No it doesnt, wierdly, each fan (3 in total) has its own PWM connection seperate to the pump, so thats 9 PWM fan conencxtions in total + pump.
I did look at the splitters, but this PWM hub is only £12 and means I can hide more cables behind also.
Ouch!
Which AIO did you go for?
Nzxt x73 (I think) 360mm.
With the size of games and todays SSD prices that tiny 250GB drive has little value, unless there's room for drives in case.
I mean Modern Warfare (against drive space) alone would basically fill it completely.
Also games might start to be developed to actually be able to use faster transfer rates of NVMes.
Already basic level NVMe like WD Blue SN550 is capable to quadrupled speed compared to SATA SSD.
https://www.overclockers.co.uk/wd-b...-solid-state-drive-wds100t2b0c-hd-56l-wd.html
So with my basic knowledge, I know I need to get a PCI-E based nvme NOT m.2?
M.2 is the form factor, so yes you need M.2. NVMe is the interface specification used for the drive you are looking at, you can also get drives that use SATA and are in the M.2 form factor these are capped at SATA speeds (obviously).
PCI-E is the bus that the M.2 slot is connected through, and thus using a M.2 NVMe drive data is passed over a 4x PCI-E lane link (if running at full speed).
PCI-E 4.0 drives are currently overpriced for general use, but you can find competitively priced 3.0 drives that will do what you need and still be better than SATA for I/O heavy workloads or faster data transfer if you need that.
