The big advantage is multiple reads and writes can be made in parallel, so you can have games and os on 1 drive.
I'd suggest going for a 1tb pcie 4.0 as a minimum now for futureproofing. The Sabrent Rocket (not the Rocket Q or Q4) is a good drive or the Gigabyte Aorous are good starting points.
Don't go for any of the cheaper cacheless drives.
Yea I quite like the look of the gigabyte aorous.
I'll see, try and decide if the cost is worth it Vs performance increase over a sata SSD.
PCIe v4 drives cost too much extra.Could you recommend a larger 1-2tb? PCI-E 4.0 nvme?
Only in case of PCIe device in a slot.PCI-E is the bus that the M.2 slot is connected through
That's never been any problem with SSDs.The big advantage is multiple reads and writes can be made in parallel, so you can have games and os on 1 drive.
M.2 SATA drives use normal SATA bus.
M.2 includes also (possible) support for USB + few more buses/connections for internal version of "try to guess what it supports USB-C type" mess.
For full PCIe v3 speed drive Adata SX8200 Pro is currently very well priced.
In both 1TB and 2TB sizes.
It's also one of the faster drives for game usage loads.
Sabrent Rocket would be another well priced.
Though Phison E12 controller is more optimized for complex workloads than home use workloads.
Some good suggestions there thanks. I think 1tb would be plenty as I also have a SATA 1tb SSD and 250gb SSD, although the latter kinda seems a little pointless if I do get a new one.
I think I probably will get one of the two above you suggested.
2tb should be plenty - I don't think the 250gb is really necessary, though it might be useful as a docs/downloads drive
Scratch drive , if that's still a thing
Just about enough for Modern Warfare.and 250gb SSD, although the latter kinda seems a little pointless...
My basket at Overclockers UK:
- 1 x Gigabyte 27" G27Q 2550x1440 IPS 144Hz 1ms FreeSync/G-Sync Compatible LED Backlit Widescreen Gaming M= £339.95
personally dont mind VA, specially as my TV us VA but most go by IPS
