SERIOUSLY AM I GOING MAD?!
26 Dec 2005
Manchester
Man of Honour
15 Jan 2006
Tosche Station
It looks like the fan is pulling from the bottom, pushing through the heatsink, especially looking at the product page.
I imagine they mounted it like this, as opposed to the fan being on the right hand side passing air through to the back of the case, due to insufficient RAM clearance, but it's hard to know for sure from your picture.
:edit: hmmm no, given it a second look and there would definitely be room for the cooler to be rotated 90deg anti-clockwise. Definitely strange, but not as bad as if it was firing down.
11 Sep 2013
Is this normal?
No... but not entirely unheard of, either.
But it looks like the aim was to push air up through the heatsink and out through the top and rear exhaust fans. It can also help drag air from the 'dead zone' beneath the GPU, up between it and the case window, which creates more negative pressure, which then draws more cool air in through the holes to feed the GPU.
Not sure how effective that really is and you generally need an powerful fan to do it, but that is the theory behind it, anyway...
11 Dec 2016
Oxford
Assuming the fan on cooler is blowing upward, not that unreasonable configuration.
I think there is some synergy in air moving from bottom to gpu to upper (larger) fan, rather than rear.
Without actual testing hard to say which direction (bottom-top or front-rear) cpu cooler alignment wins.
Man of Honour
22 Jun 2006
Wouldn't like that myself, but if it works it works? Some cases have more powerful fans in the top too (assuming that's where the air is going), one of mine has one 140mm top and one 120mm rear.
18 Nov 2007
Deepest Darkest Essex!!
You are not alone. This is a Build I did for my sister a few years back. For some strange reason, AMD decided to make the holes rectangular in their FM2+ boards so some 3rd party coolers can only be fitted horizontally.
The cooler is this one:
My basket at Overclockers UK:
Total: £31.38 (includes shipping: £7.39)​
I assumed the best air flow for a cooler would be vertically, AMD thought otherwise & it frustrated me when I built it. My own AM4 build is how it should be with a vertically mounted 3rd party air cooler.
22 Mar 2008
Not sure if you want to change it yourself, but this video shows how to do it.
Or you could show the video to the company that built it so they know how to put it right. ;)
Permabanned
23 Apr 2014
Hertfordshire
Could just flip the fan round so it pushes air out the top but then it will just be taking the heat from the back of the GPU.
I have always mounted CPU coolers so they blow air front to back out the back vent. I would rotate it if possible and just check which direction all the other fans are running in, easy to swap around the air flow.
18 Nov 2007
11 Jun 2003
Hampshire
Off topic, but have you got a drive at the bottom there suspended with bungee cord? What's the thinking behind that, never seen it before!
Back in the day this was very common, I've had plenty of PCs with bungee drive mounts. HDDs used to be rather noisy.
On topic, If temps are fine, it wouldn't bother me. My guess is there's a reason, and I'd be ringing up to find out why if you're bothered by it.
If you're picky about these things, it's always best to do it yourself; no one's going to put as much time and effort into a build as you doing it for yourself.
