1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Simple+Easy C++ Serial code (linux)
Discussion in 'HTML, Graphics & Programming' started by D.P., 5 Feb 2010.
  1. D.P.
    Caporegime
    I have a windows VBasic (gasp!) program that I need to port to C++ within a linux environment. All I need help with is the Serial communication.
    I have a device which constantly spits out a long string of bytes which I need to read. I also need to send the device a string of bytes.
    This is done through a USB-to-serial converter to an XBEE wireless serial interface. The fact that it is wireless serial shouldn't matter, the VBasic code is very transparent.
    I cannot for he life of me find any reasonable example code, tutorial, human readable help file, etc., that helps me develop very simple C++ serial communication code that works under linux. I don't want VisualStudio C++ windows only stuff. Just pure simple GNU C code.
    The Visual Basic code is this:
    Code:
    ' ENABLE BUTTON COM PORT
    Private Sub Enable_Click()
    ' SET ERROR INTERRUPT
    On Error GoTo ErrorMess1
    ' SET BAUDRATE
    MSComm1.Settings = "57600,N,8,1"
    ' Flow control?
    If FlowControl.Value = 1 Then
        MSComm1.RTSEnable = True
        MSComm1.Handshaking = comRTS
    Else
        MSComm1.RTSEnable = False
        MSComm1.Handshaking = comNone
    End If
    ' ENABLE PORT
    MSComm1.PortOpen = True
    ' CLEAR DISABLE OPTION
    Disable.Value = False
    ' LOCK PORT CHANGE
    PortCombo.Locked = True
    GoTo finish
    ' ERROR MESSAGE ROUTINE
    ErrorMess1:
    MsgBox "Please select an available port      ", vbExclamation, "      PORT IS UNAVAILABLE!"
    Disable.Value = True
    finish:
    End Sub
    ' RECEIVE BYTE FROM PORT
    Private Function RXBYTE()
    On Error GoTo error
    RXDATA = DataIN(Index)
    Index = Index + 1
    error:
    End Function
    'RS-232 MESSAGE RECEIVE HANDLER
    Private Sub MSComm1_OnComm()
    Dim i As Integer
    Dim DataSave(100) As Byte
    Dim CHECKSUM, CHECKSUM_RX As Long
    ' ERROR CONTROL
    'On Error GoTo finish
    ' RECEIVE MESSAGE HANDLER
    If MSComm1.CommEvent = comEvReceive Then
        ' Read data
        DataIN = StrConv(MSComm1.Input, vbFromUnicode)
        Index = 0
    ' CONTINUE IF WRONG CHARACTER RX
    CONTINUE:
        ' READ BYTE
        Call RXBYTE
        ' Header
        If RXDATA = 170 Then
            ' READ BYTE
            Call RXBYTE
            ' Header
            If RXDATA = 85 Then
                ' Read in Data
                For i = 1 To 70
                    ' READ BYTE
                    Call RXBYTE
                    CHECKSUM = CHECKSUM + RXDATA
                    ' Save Data
                    DataSave(i) = RXDATA
                Next i
                ' READ BYTE
                Call RXBYTE
                ' End
                If RXDATA = 255 Then
                    ' READ BYTE
                    Call RXBYTE
                    ' End
                    If RXDATA = 13 Then
                        ' READ BYTE
                        Call RXBYTE
                        ' Rx Checksum
                        CHECKSUM_RX = CLng(RXDATA) * 256
                        ' READ BYTE
                        Call RXBYTE
                        CHECKSUM_RX = CHECKSUM_RX + RXDATA
                        ' Checksum is valid
                        If CHECKSUM = CHECKSUM_RX Then
         // do some data conversion from bytes to ints etc.
  2. D.P.
    Caporegime
    I have this C++ code:
    Code:
     int fd; /* File descriptor for the port */
     /*  * 'open_port()' - Open serial port 1.
         * Returns the file descriptor on success or -1 on error.
    int    open_port(void)
       printf("Trying to open port\n");
          fd = open("/dev/ttyUSB0", O_RDWR | O_NOCTTY | O_NDELAY);
          if (fd == -1)
    	* Could not open the port.
    	perror("open_port: Unable to open /dev/ttyUSB0 - ");
          else
    	fcntl(fd, F_SETFL, 0);
            printf("I opened the port /dev/ttyUSB0  !\n");
            struct termios options;
           * Get the current options for the port...
           tcgetattr(fd, &options);
         * Set the baud rates to 57600 ..
        cfsetispeed(&options, B57600);
        cfsetospeed(&options, B57600);
         * Enable the receiver and set local mode...
        options.c_cflag |= (CLOCAL | CREAD);
         // 8N1
         options.c_cflag &= ~PARENB;
         options.c_cflag &= ~CSTOPB;
         options.c_cflag &= ~CSIZE; /* Mask the character size bits */
         options.c_cflag |= CS8;    /* Select 8 data bits */
          // Do the following to enable hardware flow control:
         //    options.c_cflag |= CNEW_RTSCTS;    /* Also called RTSCTS /
         //Similarly, to disable hardware flow control:
        //options.c_cflag &= ~CNEW_RTSCTS;
         * Set the new options for the port...
        tcsetattr(fd, TCSANOW, &options);
          return (fd);
    int main(int argc, char *argv[])
       open_port();
       int n = write(fd, "ATZ\r", 4);
       if (n < 0)   fputs("write() of 4 bytes failed!\n", stderr);
       printf("Wrote \%i bytes\n",n);
        char *buffer;
       //fcntl(fd, F_SETFL, FNDELAY);
       int recieved =   read( fd, buffer, 5);
     printf("recieved \%i bytes\n",recieved);
         close(fd);
         return EXIT_SUCCESS;
    If the serial device is not in then errros are reported, which is good. The writing works without error but I cannot check.
    But when I try to read data I don't receive anything. Actually, the whole reading part is a mystery to me.
  3. Ladforce
    Hitman
    Your buffer ptr does not point to a buffer which has had memory allocated for it.
    Buffer should be something like "char buffer[255]"
  4. D.P.
    Caporegime
    Thanks, thats true.
    I've been through the code again and it looks ok.
  5. Ladforce
    Hitman
    So your code, with the buffer change, just waits at the read() line and never progresses? Are you certain something on the other end is writing at least 5 bytes of data down the line?
  6. D.P.
    Caporegime
    I have something to check the hardware device is actually transmitting (will boot a 2nd PC and usb-to-serial-to-xbee using the windows visual basic program I know works, and can read form the linux PC). So will report back in an hour or so.
  7. D.P.
    Caporegime
