- 25 Jul 2005
I currently have the sky sagem f@st2304, wireless g, modem router which is okay at best.
I have also been using an asus rt-n66u with dd-wrt as a wireless bridge. Connecting to the sky router via wireless and allowing devices to connect by cable. This has all been working fine.
Made the decision to run some cables around the house so as many devices as possible can be directly wired into the router(with the use of a couple of switches).
In theory, this means that I can then use the asus router as the router for wired and wireless devices (as it has gigabit wired connection and dual band wireless n) which is much better than the sky router. It will also enable me to connect a USB hard drive to the network, via socket on the asus router.
The setup that I envisage is that the sky unit simply acts as a modem, I then connect this to the WAN port of the asus router.
Not so simple though, and I'm starting to confuse myself.
Sky modem router has IP address of 192.168.0.1
Asus router WAN IP address is 192.168.0.xx
Asus LAN IP address 192.168.1.1
I then disables the sky router from acting as DHCP server, leaving the asus router to distribute IP addresses. For some unknown reason this then knocked out the Internet connection. I was also then unable to access the web GUI and set it as DHCP server again, meaning I had to reset the device.
Attempted to change the settings on asus router turn off the DHCP server, this again left me unable to access the device and having to reset it.
Finally, I tried to set the asus out as a wireless access point only, but this didn't work either.
Hopefully someone can help and advise as to what I am missing so that I can get this up and running.
Thanks for your time and any assistance offered.
