1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
slight strangeness with catalyst and my 5870
Discussion in 'Graphics Cards' started by tmaxxthomson, 15 Oct 2009.
  1. tmaxxthomson
    Hitman
    hey. ive overclocked my 5870 with catalyst overdrive to max settings and its completly stable. well thats obviously not the issue. the issue is that wen overdrive is active at the desktop the 2D clocks are at 507/500 instead of 157/300 ?? and when i disable overdrive the clocks go back to 157/300. very strange. anybody else having this issue? :/
  2. Martini1991
    Caporegime
    I'm having issues, I'm dual screening, It's at 400/1200.
    So, I'm idling at 52c, not 32c =/
  3. tmaxxthomson
    Hitman
    ahh. ive not got dual screens, just a single 1900x1200 24" panel. idleing about 55 :/
  4. Martini1991
    Caporegime
    That's mad.
    I thought my 52C was bad..
    I miss my 32C :(
  5. tmaxxthomson
    Hitman
    yeah :/ was idleing in the low 40's before!! still not bad concidering my room is quite small and could be considered "tropical" haha. im nt happy with the heat. but my tarantula sure is! haha. wish i could find a solution to these damn idle clocks!
  6. Martini1991
    Caporegime
    Me too, I switched it down in CCC, but that causes tearing on my second screen...
  7. tmaxxthomson
    Hitman
    i might just completly uninstall the driver package and install some newer beta ones :/ might help! xD
  8. Martini1991
    Caporegime
    I'm on the latest beta ones as far as I'm aware.
  9. LoadsaMoney
    Caporegime
    The only solution is to run single screen, as dual screens causes the idle clocks to be higher, which in turn raises the idle temp.
  10. tmaxxthomson
    Hitman
    no dual monitors here!! still high clocks at 2D :/
  11. tmaxxthomson
    Hitman
    tryed newer drivers and everything, i just cant seem to enable overdrive without the 2D clocks ramping up to 507/500!! :(
  12. Shocky-FM
    Mobster
    Strange i'm getting 157/300 with overdrive enabled and with dual displays, however yes I'm getting tearing/flickering on the second display which is really annoying.
    I'm sure will will fix it, but knowing ATI it will take them a few months.
  13. tmaxxthomson
    Hitman
    ahh. well i dont have a 2nd display to test that but at the top of my screen with overdrive enabled and high 2D clocks i do sometimes get a shimmering/flashing in the top 8mm of my screen sometimes
