csmager said:Stability's a measure of how long the line remains synced, not a measure of the SNR margin. Even 3dB could be perfectly stable on some lines, but it's hardly a sensible place to start. 6dB is the default setting, and that's what everyone's Max line is set to on Day 1.
Why should 3dB or 6dB be any less stable on other lines? Surely it's dependant on the modem at the other end and how it's able to manage the signal.
My debut on MaxDSL began last Friday and it initially started out at a 7136000 bps sync rate @ ~6dB. Day later I was bumped up to 7168000 bps @ ~5dB. The error rate is significantly higher now but the line hasn't dropped in 24hrs.
So I don't know what the BRAS system at BT will make of that.
