Hi All,
I've just moved from a triplehead2go digital set up and gone to an eyefinity set up using a ATI5970.
I have a small problem though in that when I start the PC up I get an error on one monitor statin the refresh level is not supported. If I remove the display port connector and re-plug it in everything then works fine.
I've removed all of the Matrox software using remove software and have in Catalyst control panel the eyfinity set up and set at 60hz.
I think the issue is that with triplehead you had to run it at 59hz to work and there is probably a setting still left which is telling the one monitor to still run at 59hz.
Running Catalyst 10.2 drivers.
Anyone have any tips for this issue?
Regards
Taff
Regards
Taff
