1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Small/Low Powerd Server
Discussion in 'General Hardware' started by smoove, 21 Jul 2006.
  1. smoove
    Perma Banned
    Hi there, can anyone spec me a rig that is:
    1. Small in size (so I can put it anywhere).
    2. low power consumption
    3. pretty low spec. Will be a file server/firewall.
    There is no budget, but enough to get the above.
  2. Dave M
    "Primo" AMD Athlon 64 3200 2.00GHz DDR System (FS-004-AS)
    Seriously - those little Asus units are tough as old shoe leather, had one running for 3 years without a hiccup - it's still running actually but has been retired to a desktop machine.
  3. smoove
    Perma Banned
    Thing is, I wont need a DVDRW, sound, monitor, keyboard, mouse, speakers.
    Im looking for something that has a pretty low power consumption as it will be on 24x7.
  4. MrWhippy
    Wise Guy
    sounds like an ideal scenario for a mini-itx system.
    will be tiny and very low power.
  5. smoove
    Perma Banned
    Are they really suitable for being online 24x7?
  6. afraser2k
    Sgarrista
    The fanless Mini-ITX boards are ideal for 24/7 servers, especially when running some form of Linux as a firewall/router. Just make sure you have idequate silent case cooling.
  7. MrWhippy
    Wise Guy
    absolutely, people have clustered them to build supercomputers.
  8. smoove
    Perma Banned
    Thanks alot. How much is the norm for the lowest spec possible?
    eg, say 500mhz, 256mb ram?
  9. VeNT
    Capodecina
    VIA Epia mobo then. or a old Pentium 2/K6
  10. afraser2k
    Sgarrista
    In terms of cash you're probably better off getting the Primo system. Epia's can get expensive depending what you want out of it. A pre-built system based on Epia 533 MHz, 256Mb RAM and 40Gb HDD goes for around £286 inc. VAT from a competitor, though I don't know if I'm bordering on rule breaking for suggesting that.
    The "Primo" AMD Athlon 64 3200 2.00GHz DDR System (FS-004-AS) will be cheaper short term depending on power usage and would be able to run the Windows stuff well too if you have to change in the future (more hard disk space for a file server for example).
    A third option is to go for second-hand stuff in the Members Market. I'd say look for something about 600MHz, 512Mb RAM for a Linux server, 1Ghz+ for Windows.
  11. Dureth
    Wise Guy
    Something like the following would have seriously low power requirements, in the region of 100w.
    CP-156-AM AMD Sempron 64 2800+ (Socket AM2) CPU - Retail (CP-156-AM)
    £37.95 £37.95
    MB-056-GI Gigabyte GA_M51GM-S2G Micro ATX (Socket AM2) PCI-Express DDR2 Motherboard (MB-056-GI)
    £49.95 £49.95
    MY-013-SA Samsung Original 512MB DDR2 PC4200 533MHz (MY-013-SA)
    £29.95 £29.95
    HD-018-SA Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA)
    £43.50 £43.50
    CA-008-AS OcUK Value X-Qpack Cube Case - Silver (CA-008-AS)
    £51.60 £51.60
    Subtotal £212.95
    VAT £37.27
    Total £250.22
  12. smoove
    Perma Banned
    Isnt that just a little overkill for a basic linux filserver/smoothwall box?
    Also, its got a 420w PSU, would it draw on that 420w all the time, or would it only use what it needs?
  13. semi-pro waster
    Man of Honour
    A PSU will draw the power that it needs to supply the system, ok there are some cheap and nasty PSUs that will take more as the requirements get higher because of a terrible lack of efficiency but as a general rule a PSU for a system that is 100w will draw pretty close to that figure from the mains regardless of whether it is capable of 300w or 600w.
    Yes that would be overkill for the most basic uses you suggest, it does offer some potential for upgrades though and buying lower specification than that new isn't all that easy. I'd probably go secondhand personally, maybe even consider a laptop as most have low power requirements and are near silent, you may want to remove the battery if possible if it will be permanantly on. You should be able to pick up something around 1ghz, 512mb Ram and a 20-30gb hard drive easily under £200.
    //edit the only main issue with the laptop is how well Linux will support its components.
  14. Dureth
    Wise Guy
    Yes the above is overkill for your requirements but buying something with lower spec will cost more unless going 2nd hand. It gives you some room for upgrade, will be pretty low power and pretty low noise. It's not the perfect answer to your problem but it is the best compromise between price and power without going 2nd hand.
  15. Gibbs
    Wise Guy
    i have a socket a duron 700Mhz if your interested. Plus also have a celron borad/cpu/ram in a box. not sure what spec but its good enough for your needs.
    Also i have a mate who is looking rid of a AMD XP 2500+ Mobile CPU if its any use.
    for a sime file server it doesnt take much.
  16. smoove
    Perma Banned
    True, but this box will be with me for years (I hope), and wont need any upgrading at all. Im a little concerned about using a laptop 24x7, since they're not designed for this purpose?
  17. a1ex2001
    Capodecina
    I'd go Mini-itx I have a file server based on the really basic fanless 500Mhz EPIA which ran 24/7 while I was a student without a hiccup, uses next to no electricity and is more than powerfull enough to run a linux file wall with samba for you file serving needs.
  18. semi-pro waster
    Man of Honour
    Maybe not designed for it but they can certainly perform the task admirably. At uni I shared a flat with 3 mates and we used my laptop(PIII 850mhz, 128mb Ram) as the server for routing the internet connection when the original server(PII 233, 256mb Ram) died, it was left on for weeks at a time so the battery is knackered true enough(hence my suggestion for removing it plus it will create less heat) but make sure it has enough airflow and it is fine.
  19. Dureth
    Wise Guy
    Or you go for a decent router and a NAS system for the same price. Much lower power and some of the NAS systems can be loaded with custom firmware. Will come out at the same sort of price too.
