Sorry to hear it Drex, but I'm sure you'll have her back as good as new soon enough, and at least it happened under safe circumstances on a track, and you're ok!
Lowe said:Sorry to hear it Drex, but I'm sure you'll have her back as good as new soon enough,
Bug eyes for the losepenski said:He refuses to take the lights off
*n
karoshi said:to be honest drexel i'd say to smooth out the two stub ends that are left into mini-corner bumpers and leave the gap across the middle.. not having it there shows off the fmic / radiator much better
I was thinking the same earlier. He might ahve to do some stiffening of the corners though, as when travelling they might bend and crack.karoshi said:to be honest drexel i'd say to smooth out the two stub ends that are left into mini-corner bumpers and leave the gap across the middle.. not having it there shows off the fmic / radiator much better
spaceman said:took a pic of you motor when it was parked on the stand, with drift damage
gaz1234 said:Jap Crap!
but the from another angle it looks a bit akward as the 'nose cone' part sticks out a bit far with nothing underneath it.
It also means that the intercooler is the first thing to hit anything
DreXeL said:I like my mutated frog eyes
