1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Sony Xperia m4 - not fit for purpose!
Discussion in 'Mobile Phones & Tablets' started by Hamish, 3 Mar 2016.
  1. Hamish
    Mobster
    So last month I decided to upgrade from my iPhone 5. I have had iPhones since the 3G.
    I decided on the Sony m4 aqua as the price was good, the form factor was nice and the reviews were good and I liked that it was waterproof.
    All was good for a few weeks. However now I am realising that the 8gb storage that comes with it makes the phone not fit for purpose. I thought a 128gb sd card might help but to no avail. The android OS takes up 4gb and the uninstallable Sony apps take up 3.5gb. Once you set up your phone and update all the apps you are already low on space. I have uninstalled almost everything to the point I have literally 3 10mb utility apps and I am still in a position where I cannot update any apps or even check my email with the Gmail app!
    I have tried apps like link2sd but these don't seem to work as I don't have root.
    I am going to try to return the phone as not fit for purpouse and get a z5 or another iPhone but I worry it's been too long now.
    Not a great introduction to the world of android!
  2. dbmzk1
    Sgarrista
    Put simply... Don't buy a cheap crappy phone and expect it to be anything other that cheap and crappy.
  3. Hamish
    Mobster
    It's a mid range phone by a respected make sold on the high street. I'm not expecting flagship performance but I expect to be able to install a few basic apps and keep the phone updated.
  4. manic_man
    Mobster
    You're comparing a phone that costs £189 sim free with one that had a headline price of nearly £600 when new and still sells for close to £150 as a second hand refurb.
    I know I'm only re-iterating the first response, but how can you have imagined these two handsets would be comparable in any way??
    Go and get yourself a Galaxy S7 or a Xperia Z5 etc. and then you can see whether an Android phone can be comparable to an iPhone!
  5. manic_man
    Mobster
    Just for reference, my Galaxy S6 has 32GB of storage (and still costs significantly less than the equivalent iPhone either sim free or via contract) and I am not even close to filling its memory. You're correct, 8GB isn't enough for a decent Android experience these days, that's why your handset was (by Sony standards) bottom dollar.
    Just to offer something hopefully slightly useful, as you have your own SD card installed as well, you can offload some of the storage being used on your devices memory to the SD card. You do this in the "apps" portion of the system settings, there should be a button marked "move to sd", it won;t move the whole app but will move as much as it can. It can't be done for every app though and there's a chance Sony have removed this functionality in their newer handsets, my last Sony device was a Z1.
  6. Fourstar
    Wise Guy
    Out of the box / after a factory reset 7.5GB out of the 8GB storage is used? :eek:
  7. silverblack
    Wise Guy
    I think its due the Marshmallow update that would allow it to use an sd card for internal storage.
  8. SexyGreyFox
    Man of Honour
    Exactly this and this is why so many iPhone users have a bad experience of Android.
  9. Richie
    That must be some mistake. I bought my dad the M4 recently and no issues... Let me check his storage next time I am over but there should be no way that the OS/Stock Apps should take up 95% of the memory :eek:
  10. Warp279
    Wise Guy
  11. phil675
    Mobster
    Should have gone for a Z5c absolute bargain.
  12. OspreyO
    Mobster
    Is it not twice the price?
  13. Third Opinion
    Having the exact same problems with mine as the OP. After updates the phone only has a couple of hundred meg. I have set it up for file transfer on charge but I am literally clearing the cache daily to get that few meg just to install an app.
    I am not a big phone user but I admit I have used lots of cheaper phones that work a hell of a lot better than this.
    After last update I am having loads of compatibility issues. It seems if you want to pair it to something that isn't Sony, it no longer works.
  14. OspreyO
    Mobster
    The limitation is the 8GB of RAM. Also Sony and Google Bloat that you can't uninstall. Also apps that you can't move out of internal storage, depending on which Sony/Android version of the OS.
    With IOS and Android, 2GB of RAM and 16GB of internal storage is the new minimum. THough if you have the latest version of Android you can use the SD card as internal memory, ish.
  15. Alpherah
    Sgarrista
    People blast Apple all the time for having 16gb storage but at least you have enough space to use the phone - I can't believe any company would be dumb enough to have just enough space for the OS and non removable apps and nothing else - it would like there being a 3.8gb iPhone option.
    Regardless of the price this is a ridiculous decision
  16. OspreyO
    Mobster
    Apple keep 8GB phones going for far too long, also they have no SD card. 16GB is probably barely enough on Apple.
  17. Cleisthenes
    Sgarrista
    Z3c is still the one I'd recommend
  18. tom_e
    Man of Honour
    It's a shame Sony have removed Android Marshmallows ability to use an SD as true internal storage.
  19. scrivz69
    Wise Guy
    Can you not root it and uninstall some of the Sony bloat.
  20. Orcvader
    Capodecina
    Also a shame a few others are doing it too. Can't they have some sort of built in test to check speeds of SD cards to see if they deem it fast enough to use for adaptive storage?
