1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Sound muffled/distored on Toshiba laptop
Discussion in 'Laptops & Tablets' started by vipergrm, 9 Mar 2010.
  1. vipergrm
    Gangster
    Hi guys,
    I have an issue with the sound on a Toshiba Equirum laptop. When playing ANY kind of sound it is all distored and you cannot make anything out. Oddly enough when I plug in a pair of headphones the sound works perfectly through the headphones but then it also plays fine on the laptop speakers simultaneously. This suggests to me that the sound isn't terminating correctly when I plug in a pair of headphones. Is there an easy way to fix this?
    Incidentally, I have tried re-installing drivers and even the operating system to no avail. Laptop is running Windows Vista Premium.
    Thanks all!
  2. beermonster
    Mobster
    Sounds like the headphone jack is damaged, and not turning the noise cancellation on. Repairing the socket by taking one from a dead board or replacing the motherboard is your only option I would think.
  3. rickyt
    Hitman
    I've had this on a Advent laptop and now on a non branded PC at work .The windows start up tune is all distorted and it was since a MS update was installed.The laptop is OK now after a format and OS install ,but I may have to do the same with the works PC .There has been some faulty MS updates of late .
  4. beermonster
    Mobster
    OP has done an OS reinstall, its definately a hardware fault, quite common on laptops as the sockets are easily damaged.
  5. vipergrm
    Gangster
    Thanks a lot guys. Looks like this is going to have to be a new board then. Must see if I can get one from Ebay. Very much appreciated. Thank you!
