1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Spec me a router for my o2 connection
Discussion in 'Networks & Internet Connectivity' started by peter212693, 18 Feb 2010.
  1. peter212693
    Wise Guy
    Hi all,
    Currently using the awful o2 wireless box II. Was looking for a new router.
    Dont have loads of money to spend, just want something reliable. I had a DG834GT but been having loads of routing problems with this like most people :(
    Thanks
  2. anything I don't mind
    PermaBanned
    i use pfsense, stable.
    you can install it on a computer with two network cards. if you need wireless then just buy netgear. although i wouldn't buy netgear myself.
  3. Locky
    Capodecina
    what do you mean by routing problems?
  4. peter212693
    Wise Guy
    Have a quick google for "o2 loss of routing problem" there is loads about it.
  5. Locky
    Capodecina
    You can spoof the MAC from the o2 router to sort out any routing problems.
  6. peter212693
    Wise Guy
    I tried that :( no luck with it tho
  7. Awahwah
    Wise Guy
    If using a Netgear rtr with a Broadcom chipset you will need to telnet to the rtr and enter the following commands:
    echo 0 > /proc/sys/net/ipv4/neigh/nas0/ucast_solicit
    echo 0 > /proc/sys/net/ipv4/neigh/default/ucast_solicit
    Remember that these will need to be applied after ever re-sync or reload.
    You will also need to add the following firewall ruleL
    - Service type: BOOTP_CLIENT
    - Action: ALLOW always
    - Send to LAN Server: 192.168.x.x
    - WAN Users: start = 82.132.253.0 finish = 82.132.253.254
    - Log: Always
    Change the xx's to your rtr's IP Address.
    Your cook ok with these entered.
