Hi, I have a GTX 1080FE, which I will be overclocking. I have also just ordered the Skylake 6700k bundle, which I will overclock to 4.5ghz as advised.
I have an existing watercooling loop but my pump has had it's time and the radiator is an old 240mm. I would like to upgrade these so could someone please advise what my best options are?
I want a silent pump. I would think a 360mm radiator would be ok, but have scope to add in a single 140mm between CPU and GPU if required, although would prefer to keep the cost down if possible to just the 360mm.
I have a bay res already, but with no pump in as I was under the impression bay res/pump combo's can be loud and cause vibration noise too? I am happy with an external pump but a bay res/tube one would work too. Case is a Corsair 800D
Thanks in advance
Thanks in advance
