Intel Core 2 DUO E6300 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail (CP-126-IN)
£152.69
Intel DP965LT 965 (Socket 775) PCI-Express DDR2 Motherboard (MB-011-IN)
£88.07
G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS)
£135.07
Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£160.92
Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE)
£61.69
NEC ND4570 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-030-NE)
£25.79
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£17.57
Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN)
£64.57
OcUK Value Hanns-G HW191D 19" Widescreen LCD Monitor - Silver (MO-017-OK)
£140.94
Logitech Cordless Desktop EX-110 - Retail (KB-072-LG)
£23.44
Total inc VAT: £870.75
If you overclock that E6300 to 2.4GHz, it will perform roughly the same as an FX62, and there's no reason why you can't achieve 2.4GHz++ with the above spec. As for the monitor, I'm not sure how it compares to the ones you mentioned above, but it's the same price as the Hyundai and has better specs on paper (but as a general rule, try to spend the most you can on a monitor as it's the one thing you look at most when you're on the PC). Bit over budget though so...eek...
