1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Speed Accuracy
Discussion in 'Motors' started by Captain Kirk, 24 May 2006.
  1. Captain Kirk
    Hitman
    I was having a "debate" with a friend the other night (whilst drunk) on speedo accuracy. I said it was crap, due to so many different factors (i.e. tread depth, tyre pressure, sensor accuracy etc) and that TOMTOM on my pda was a lot more accurate due to the gps. Could someone settle this argument or add any other comments on which one is more accurate. Cheers
  2. Acolyte
    Mobster
    GPS is far more accurate compared to your speedo.
  3. Glaucus
    Man of Honour
    debate closed.
  4. MrMatteh
    Wise Guy
    how could tomtom be *less* accurate is what you need to ask your mate
  5. Psycrow
    Mobster
    GPS is accurate to something like 0.1m/s with a 3 or more satellite lock. Your speedo can be up to 10% out due to the many many little errors that mount up as you go through the system.
  6. Nozzer
    Banned
    Unless you're going up/down hill. But it's still more accurate at a cruise.
  7. NathanE
    Capodecina
    How comes? GPS can determine altitude too ya' know? ;)
  8. Nozzer
    Banned
    Simple trigonometry, my dear boy.
  9. Captain Kirk
    Hitman
    Thank you, I knew I was right. I don't like being wrong, and I'm not very often :D
  10. The_Dark_Side
    Capodecina
    so when you're at warp 9 does you're speedo read slow or fast?
  11. PMKeates
    Capodecina
    Mine just says 120mph, so definitely slow :confused: :D
  12. Captain Kirk
    Hitman
    At about 70, it reads around 65, so need to do about 75 according to speedo to be doing a real 70. In theory
  13. Dr Who
    Sgarrista
    Speedo accuracy varies at the speed you are travelling at...
    My accord was about 5mph over at 50 mph, at 100mph it was 1mph different to the tom tom gps!!!
    :eek:
  14. daz
    Capodecina
    I think you mean at 65, it reads 70. T'other way around. :o :p
  15. Lashout_UK
    Capodecina
    Speedo in the 1850 was spot on.
    Speedo in the 1500....doesn't work, Officer :p
