Jumpingmedic said:Can u n0t und3rst4nd wh4t 1 am s4ying?
That example is only 2 letters short of a proper english version. Why substitute the letters with numbers? It's hardly abbreviating anything, I just don't get it.
Chasser said:That example is only 2 letters short of a proper english version. Why substitute the numbers for letters? It's hardly abbreviating anything, I just don't get it.
Spuderoony said:No, you misinterpret me, I think.
I don't necessarily think that "proper" (whatever that is - everyone could define it differently...) English should be used. I think the most appropriate form according to patterns of language use at the given time should be used. Currently, that would be Standard English.
I'm afraid you're going to have to explain how the internet can be described as being a country. And unofficially, its language is English. Circa 80% of all webpages are written in English.Jumpingmedic said:The Internet can be described as a country under certain definitions, why shouldn't it have it's own language.
Do it, you got everything wrong.sniffy said:E-mail Gilly?
Just finished second year of a degree in it at Leeds University.Andelusion said:Anyone in the thread here take English Language at A level or higher?
I'm just curious, as I've just finished an A-Level in it that's all.
Spuderoony said:Just finished second year of a degree in it at Leeds University.
Gilly said:Do it, you got everything wrong.
You complained that phonetic spelling looks dumb. I did assume something at this point, I understood that from this you would believe the same whether it was written by hand in a letter or typed out in a post on this very forum.sniffy said:No, you can't quote me specifically because that simply isn't what I said.
Where did I fault your spelling?sniffy said:OvertoneBliss's point on the other hand is quite right. My use of slang is incorrect in the written word, you didn't point that out though. You faulted my spelling in my original post, which there was none.
I didn't accuse your spelling of anything of the sort.sniffy said:I said I didn't like phonetic spelling. You then accused my spelling of being "child" like (you confirm what Lopez said; that being I spell poorly), which I then point out that isn't what I meant, nor that any spelling is actually incorrect in that section of quote (only my use of the word "done" which is a local dialect issue, which Overtone pointed out). You then say "You were talking about employing different spelling. In case you hadn't realised, that is a main component of post structure". Ok, let’s clarify on your term "post structure". A post is in essence, a bunch of sentences. Ok, so sentence structure?
You see no emphasis on spelling on any sites you visit? This entire thread is about spelling, so other sites - specifically ones which 'don't place emphasis on spelling' - have no business being discussed here.sniffy said:I see no emphasis on spelling on any sites I visit. I'm not sure who to believe here, you or people who are experienced and qualified in their field of work. Hmm :/ I can see your point, but it doesn't apply to the term sentence structure.
Post structure, sentence structure, all the same thing.sniffy said:I'm going to guess your term "post structure" doesn't mean that though?
Gilly said:You complained that phonetic spelling looks dumb. I did assume something at this point, I understood that from this you would believe the same whether it was written by hand in a letter or typed out in a post on this very forum.
In the very same post you had errors. This I quoted to point out the irony of your complaint. You complain that people spelling words phonetically as opposed to correctly looks dumb. Alongside that, grammatical errors look worse.
Good start.sniffy said:You're correct.
Well, actually, I was pointing out how dumb it was to call other ways of typing words dumb, when your own command over the English language isn't fantastic. So much so as to allow errors in the very post you call others dumb.sniffy said:So you suggested I was dumb due to my use of regional dialect ("grammatical errors" as you put it)?. I'm not going to say my use of English was correct but to brand regional dialect in the written form dumb (through use of irony or otherwise) is silly. Saying "turnt" was pretty stupid of me as it isn't even a word, just how it's said. People who aren't from my region of England might be confused but that doesn't matter as that isn't what you quoted.
One assumption is correct, the other is not. I thanked Leon (thats the correct one, that is Lopez, no-one but he and I needed to know to whom I was referring) for pointing out how daft you were to throw your teddies out of the pram in the way you did. A simple 'Oh, yeah, my mistake ' rather than somehow reading my post as calling you childish would have sufficed. Later, a simple post saying 'my bad Gilly, I thought you were calling me childish, sorry' would have sufficed when everyone else told you that you'd overreacted and missed the point.sniffy said:You said "You completely missed the point. I didn't call you a child". You then saw Lopez's post which clearly states I used "poor spelling" and then you edited your post saying "[edit]Cheers Leon". I made two assumptions here. Firstly it seems by you thanking Leon, he made the "point" that I "completely missed" (his point being I was upset because my poor spelling was noticed). Secondly that the "Leon" you refer to is Lopez.
No, I did not.sniffy said:You certainly did.
I don't understand any of this quoted text. Are you saying that using words in the correct tense isn't necessary for correct sentence structure?sniffy said:My link ties in perfectly with your definition of "post structure" though, which that link (and many others if you check google) disagrees with. I used that link to highlight that. Surely you can't make a statement on a point that doesn't exactly tie in with the topic then disregard any links that prove that statement false? That would be silly
Gilly said:Good start.
Regional dialect is all well and good, but using words in the incorrect context and/or tense is simply wrong and misleading, especially over simple text where inflection and tone aren't possible.
One assumption is correct, the other is not. I thanked Leon for pointing out how daft you were to throw your teddies out of the pram in the way you did.
No, I did not.
It was you that wanted me to post in here, if you remember, rather than take it to mail.
