1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Stuck at 3.5 any thoughts?
Discussion in 'Overclocking & Cooling' started by imamosher, 24 Apr 2010.
  1. imamosher
    PermaBanned
    @3.5 1.4125 vcore 58 degrees max temp stable. Should I try putting anymore through her?
  2. BigBruiserAl
    Mobster
    yes go go go
  3. imamosher
    PermaBanned
    not sure where to go next with it, temps are getting a bit high.
    Should I just keep increasing multi or bump on the vcore too?
  4. g0cem
    keep increasing the multi until the computer fails then start increasing the vcore voltage
    but keep an eye on your temps when you are doing this
  5. eddyc
    Wise Guy
    I would not go any further. Temps are looking too high. What settings are you using to get that clock speed?
  6. sir-les-mp
    Wise Guy
    I would agree with eddyc Temps are getting close to the 940's max temp of 62c
    the only way i would push further would be to improve cooling for the cpu.
