And you use a £70 motherboard to judge the quality of the entire line of products made by that company?
When that board was first released it was £130
It has been such a massive success that they were able to lower it and now it can be had for half the price yes.
It has been around for some time too, which again, also owes this because it IS such a perfect motherboard.
I am seriously struggling to think of any other board by ny other maker that has been on sale for as long as this board has, and stil sells in such high numbers.
Those simple little fact speak volumes in my book.
And its also why I have owned 4 in the past and still own 2.
If you see a £70 motherboard with barely adequate tiny heatsinks on it, you should be able to tell that its not going to be as good as the higher end boards which cost a lot more and feature much better cooling and maybe better quality components.
Again, the DS3 came out at twice that price.
Has a massive ( if still inadequate ) Heatsink cooler
And was the first to introduce ultra reliable Japanese Caps
The board was also available in a cheaper version called the S3 as opposed to the DS3 and this was 100% identical but used standard Caps instead of solid ones.
But the DS3 was among the first to get Conroes into 500MHZ Territory even with their stock Heatsinks.
Mine however, all have Zalman cooling... Just in case.
But the DS3 is pretty much the grand daddy of so many other motherboards now, that to say he is judging over one board would be wrong... There are dozens in Gigabytes range that are basically DS3 Boards with "adjustments".
