System not reading full amount of memory?
18 Oct 2002
Isle of Wight
So you're running a 64bit OS and have tried everything but the bios and Windows cannot use / see the full 4 or 8GB? My friend had this problem with his 2x4GB modules and Win7 64bit. The solution? Re-seat the CPU. Job done.
Just thought I'd post this here in case anyone else encounters this odd problem :)
6 Dec 2012
can't say i've heard it it, but will file it into the brain so thanks for sharing it, all knowledge is better shared, as odd problems are just that, odd....
OP
18 Oct 2002
Isle of Wight
Yeah we laughed it off before but it does make sense! We'd tried everything from upgrading the BIOS, entering the memory settings manually and different modules...
Thought it was worth sharing :)
