You tried those settings I posted in the other thread?
I forgot to mention you need to create another connection (call it T-Mobile Proxy Test or something similar to seperate it from the others) otherwise you can run into some problems.
- Select Start
- Select 'Settings'
- Select 'Connections'
- Select 'Advanced'
- Select 'Select Networks'
- Select the top 'New' button
- Give it a name (e.g. 'T-Mobile Proxy Test')
- Click the 'Modem' Tab
- Click 'New'
- Enter a name, e.g. 'T-Mobile GPRS Test'
- Select 'Cellular Line GPRS' from the drop down list
- Select 'Next'
- Enter the Access Point Name as 'general.t-mobile.uk'
- Enter the user name 'user'
- Enter the password 'one2one'
- Click 'Advanced'
- Click 'Servers'
- Enter the DNS servers 158.43.240.4 and 62.241.160.200
- Select OK
- Press 'Finish'
- Click the 'Proxy Settings' Tab
- Click 'This network connects to the internet'
- Click 'This network uses a proxy server to connect to the internet'
- Click Advanced
HERE YOU NEED TO ENTER THE PROXY DETAILS
- For HTTP enter: 158.43.240.10:3128
- For Socks enter: 158.43.240.10:1080
- After entering the details, click 'OK'.
- Ensure that in the top drop down box your new network is selected.
- Disconnect your existing connection
- Try browsing!
I found with these DNS and Proxy settings the web pages you request are found and loaded far more quickly than the slow default T-Mobile settings.
Ok, so running the speed test posted in this thread doesn't return 1.2Mbps (got 263kbps with the network setting posted above) but I'd take the faster browsing speeds over faster downloads anyday. Until T-Mobile sort out their terrible DNS and Proxy servers, I'll be using the alternative option.
MSN is blocked with this proxy but a download of Agile Messenger soon sorts out that little problem.
Another tip regarding the camera.
For some strange reason, the sharpness is set to 5 by default. Reduce this to 1 and notice a massive improvement in the picture quality. Setting the contrast to 1 also helps in certain situations.
