1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Temp monitoring using iPhone
Discussion in 'Windows & Other Software' started by Guitarman0, 19 Apr 2010.
  1. Guitarman0
    Wise Guy
    I have seen around that you can monitor your macs temps
    using istat pro and an iPhone app. I recently asked in a thread the best way of monitoring temps while in a full screen and am wondering if there is any way to stream the temps over to the iPhone from my PC (just like istat would for the mac). Thanks
  2. lokkers
    Wise Guy
    The simplest way to do it yourself would be to write a web app, host it on the machine you want to monitor and open the page using Safari on the iPhone. I don't know of any native iPhone apps to do it.
    That's what I would do anyway. Or just buy a second monitor...
  3. mast3r
    Mobster
    the "Write a web app" Makes it sound really easy :)
  4. lokkers
    Wise Guy
    It's not that hard really.
  5. Azuse05
    Wise Guy
    The only pc program I know like this is the RC Tweakit that comes with the Rampage III mobo and it's bluetooth module. Apart from that it'll probably have to be a home job.
    P.s. I'm sure afew ppl would be interested :)
  6. mast3r
    Mobster
    It isnt if you know how to do it!
    :D
    I wouldn't have a clue.
  7. lokkers
    Wise Guy
    Unsurprisingly the web aspect is pretty straightforward. It's getting the temperature data that's going to be the bugger. I might have a play and see if I can knock something up. Reckon the best way would be to use Speedfan to get the data (like some Sidebar gadgets do), but it's integrating with that which is awkward as there don't seem to be any guides. Ho Hum.
