1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Temp question
Discussion in 'Overclocking & Cooling' started by yfas29, 9 Jul 2010.
  1. yfas29
    Hi all,
    My new build's cpu and system temp is currently idling at around 43c. So given how warm it is at the moment and the high room ambient, would you say that the above temps are ok?
    My spes are as follows:
    Gigabyte GA MA-785GM-US2H
    Phenom II X2 555BE @3.6ghz all cores unlocked 3.9v
    4GB Corsair XMS2 DDR2
    Geforce 9600 GSO.
    Cheers
    BTW My cooler is a Coolermaster Hyper 212+ seated with AS5
  2. RJC
    Don
    Ideally you need to run the cpu at full load with Prime and check full load temps.
  3. yfas29
    After 5 mins of prime 95 temps were 54c!
  4. Chris_83
    Gangster
    54c is nothing to worry about. When it hits 70+ then start to worry
  5. pooley
    Mobster
    yeah 54c load temps are fine.
  6. RJC
    Don
    Temps are fine :)
  7. OLDPHART
    You need to run P95 Small FFTs for at least a hour, to get a better measure of your temps.
