Don’t worry; be cool Adam, it’s Gonorrhea back in the garage.
I'm needing some new snowfoam and a polish.
I have been impressed with some of the Autobrite product I've had and know they have a sale on however it is 3 for 2 on Autoglym at Halfords and I can also get 10% Bluelight discount.
The main reason I need the polish is to cut back some slight oxidisation on the caravan roof... Autobrite renew seems to have done the trick for the black marks however I'm thinking maybe a medium compound might be better?
What level of cutting would you say the Super Resin Polish is? Similar to the renew or slightly more aggressive?
Thoughts on the Polar Wash Pre wash from autoglym?
For all cars/caravan I've been using a TFR non Caustic snowfoam, dry and then use the Cherry Glaze with a Spritz of Project 64 on top. Never really use a soap and bucket so anything to help with the wash stage is appreciated.
@GinG have a look a the Bilt Hamber range. There snow foam is really good.
Have a look at cleanser polish.
https://www.bilthamber.com/waxes-polishes-and-clay-bars/cleanser-polish
What mix do you use with the snow foam? I tried 50:50 this week and it wasn't very thick.
Stick to snow foam Lance..Just got the new karcher k3, what's the detergent bottle on the back like for the likes of magifoam? Any good or stick to the snowfoam lance
Thanks for the reccomendations so far anyway...pics of the caravan after having the first wash since November having collected from Storage.
I used the last of Jennychem Snowstorm TFR
Rinsed
Polished with the last of Autobrite Renew (ran out for the roof!)
Layer of Cherry Glaze
Layer of Project 64
Layer of Astonish Spray & Shine as a quick detailer
A few before and after below:
Just stuck it for today, looking on YouTube it doesn't look to greatStick to snow foam Lance..
that’s a good effort! How long were you on that?
