Nelson said:From the sound of it your flush problem is more likely to be a damaged diaphram in the syphon.
SeanyK said:Hardly...Its watercooled!
<bad I know!>
<bad I know!>
Zap said:why...had he pulled?
<bad I know!>
Von Luck said:Surely you do? The ballcock needs to go higher before it cuts off the flow of water. Having the ballcock lower would cut the flow with less water in the cistern.
What Nelson has said looks right to me.
if you want the water level in the Cistern to rise, you want the ballcock to go up.
KizZ said:
