Mad old tory said:Darkside/Lopez why specify the LHD golf mk1?
The_Dark_Side said:post#25 my friend
Mr_Sukebe said:Maybe he's refering to the LHD only 16v version? I bet that it would have been somewhat interesting.
because the car was first and foremost designed to be in LHD format with RHD versions an afterthought....after all the RHD market for a car like that isn't exactly large.converting to RHD involved a lot of linkage to the master cylinder etc that remained on the n/s of the car and every joint on each piece of linkage of course had some "play" in it.add them all up and the pedal felt like it was connected to a blancmange.Mad old tory said:Darkside/Lopez why specify the LHD golf mk1?
easy tiger, only messing with you.Shootist said:Ok, thanks for that.
the Golf wasn't LHD only though .malc30 said:Which is why the Lancia Delta Integrale is left hand drive only aswell.
there's a nice design fault on the Escort RST.Mr_Sukebe said:Should we add the R5GTT to the LHD is best option.
I read that the 2nd generation GTT ended up with the fuel line going somewhere near the turbo due to the RHD conversion, sometimes resulting in fuel vapourisation at high speeds. Nothing like getting engine cut out at an indicated 130mph.
1220kg, unless it’s the rare Dakar version. Yes, light for a 4WD rally type, but we’re talking hot hatches, and relative to my ideal for a hot hatch. Having owned both GTi-R and Sunny GTi, the extra 120kg of the R makes a significant difference, making it feel more like a mid-weight car, which is getting away a smidge from the nippy, effortlessly chuckable handling, which for me defines a hot hatch. Just my preferenceStonedofmoo said:The Pulsar GTi-R was the lightest of all the period roadgoing rally cars. In fact at 1200kg or less depending on what model you went for, it's pretty damn light by any standard.
This was reflected in the fact that it was quicker at accelerating than all those cars of the time including the Escort Cosworth
It also gets my vote
Firestar_3x said:1. MK1 Golf GTI
2. Pug 205 GTI umm not sure 1.6 or 1.9..
3. Renault 5 Turbo
4. Clio 172 Cup
5. Saxo VTS
