1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Total Linux n00b: low spec system.
Discussion in 'Linux & Open Source' started by DreXeL, 11 May 2007.
  1. DreXeL
    Man of Honour
    I've chucked together this POS out of bits I had lying about:
    AMD K6-2 500
    160mb ram
    32mb Kyro 2 graphics card
    6.4gb HDD
    It's going to be hooked up to my TV and a wireless keyboard with built in trackball, and used exclusively for web browsing.
    I'm thinking Xubuntu will do the trick?
  2. BillytheImpaler
    Man of Honour
    I've run Xubuntu on a similar spec and it was quick enough. If you try it and it's not up to your standards you might wish to try DSL, a distro built specifically for low-end hardware. The only trouble I see is the memory. It's always a case of the-more-the-merrier with memory.
    EDIT: Remember to get the alternate version rather than the "Desktop" version. The difference is that the alternate does not include LiveCD functionality and will install on machines with less than 192 MiB RAM like yours.
  3. gumbald
    Sgarrista
    If possible, bump that RAM up as much as you can, it really makes the difference :)
  4. saffyre
    Hitman
    Should be fine even with that ram. Fluxbox is also worth a try as a WM, its prob more lightweight than XFCE. Good WM tho.
  5. 900I
    Gangster
    Run Vector Linux standard on that spec m/c mate, I would.
